Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: V6CDTi - Oil shot after just 6k miles?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default V6CDTi - Oil shot after just 6k miles?
    I had an oil change at 215,000km and the GM LL oil was shot after 20,000km (dirt particles on dipstick) so right when I intended to do an oil change.
    Now, the Castrol Edge TurboDiesel 5w40 is looking the same after only 10,000km! Surely that's not normal for an oil like Castrol? Or is my engine simply too dirty now? I suppose an engine flush is out of the question for a 150k+ mile V6CDTi, or is it?
    Which oil should I use? I was really happy with Mobil 1 5w50
    Should stress that the engine uses negligibly small amounts of oil between oil changes (15-20,000km).
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Vauxhall use long life oil might make a difference?
    Regular Member Jezzy's Avatar
    S.E
    Have you been driving to Austria again??
    Diesel engine oil will become very dark within a few miles from new
    Inspect it daily, as per handbook
    The Long Life oils are designed to hold a large amount of contaminants
    Mine lasts to about 15K miles and then deteriorates rapidly, but by then it looks like treacle but is still very fluid
    However, by 20K miles and the service indicator appearing it starts to appear thicker
    My current oil is about 5K miles old and is already looking like black paint, but the service indicator shows it is still as expected
    How does the Castrol Edge Turbo Diesel 5W40 compare to the OE oil / specification?
    Full Member Big Sig's Avatar
    I have my reservations on 5w30 oil in high mileage engines, but if yours doesn't use any then it must be ok. Unless yours doesn't use any when running 5w50?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The Edge oil is within GM spec for diesel engines. The handbook states it's fine to use 5w40 so thought I'd try it since it's a Turbo Diesel specific oil.
    As for the 5w50 oil, I had absolutely no oil consumption in 10k intervals (used it for 2 oil changes), and nearly no oil vapour/fumes when the engine was hot as opposed to the GM 5w30 and this 5w40. Neither the 5w50 or 5w40 are Long Life spec oils.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    We use 0w40 mobil 1 in our cars we service
    Jun 2011
    Elland
    You've been hammering the car since you've sorted some of its' issues... more loud pedal, more soot, dirtier oil
    How does the 'oil life remaining' indicator work on these? I can opcom the life left in %. If it actually does some sort of measurement of the oils' quality, then this could be an indicator of whether the oil is shot... else it could just be based on distance travelled and number of cold starts... anyone know how 'clever' this indicator is???
    Millers oils are considered the dog's danglies here. Not cheap, but they do make some cracking oils. They have got outlets in Europe. They recommend 2 sorts for the Y30 (same recommendation for the Z30, just the Z has to have it changed twice as often)
    http://millersoils-online.co.uk/mill...exact_match=on
    or
    In the performance profile for the oils, Castrol does not come up as an equivalent product...??????
    Mileage : 000
    Quote Originally Posted by mattv6diesel View Post
    Me too, have used it in quite a few of our cars over the years.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by hebblemarine View Post
    The 5w30 GM LL oil I had in suffered Germany three times and twice as many km's, yet remained un-sooty.
    However, the engine was slightly noisier, there was a lot more oil fumes coming out of the filler cap, and my mate said the car puffed out a bit of blue smoke when I really hammered it. None of which ever happened with the thicker oil (5w50).
    I don't like the 5w30 oils purely because the oil temperatures in this engine are REALLY high most of the time, and since I drive quite fast (even faster in Germany), they just get higher. The oil needs to maintain its lubricating properties and I think the 5w30 oil is simply too thin...
  1. 4 months and 10k miles with no major problems - V6CDTi
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2010, 22:58
  2. Vectra V6CDTi
    By sb1uk in forum Engine & Drivetrain
    Last Post: 11th March 2010, 20:21
  3. First pic of my V6CDTi SRi
    By fandango in forum Quick Photo Album
    Last Post: 2nd March 2009, 14:46
  4. Which oil?? 3.0 V6CDTI
    By chrisd in forum Engine & Drivetrain
    Last Post: 3rd January 2009, 20:38
  5. what to look for in a V6cdti
    By dannysport18 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2006, 22:03
insignia cdti revs 900rpm and smokes
y30dt overheating
