Thread: Service Indicator
    Default Service Indicator
    when i purchased my car one of the pre-requisites from me was that i wanted a full dealer service, which was done. This was completed and i have the stamp in my service book. However since about two days ago ive has the service indicator light on (see attached pic)
    simple question .... how do i turn this off?
    Regular Member Boris's Avatar
    North Shropshire
    Very simple.
    With the ignition off, press and hold the trip counter reset button on the speedo.
    Still holdig it, turn the ignition on and hold for approx 10 seconds.thats how i do mine.
    If it keeps coming back on then you have a problem. There was an issue with some Vec C's with this. Take it back to the dealer if it keeps doing it. If it's one of the ones affected, they will initially update the software. If it persists then the final fix is to replace the instrumentation! I think Graeme had this problem and ultimately had new instruments.
    I'll dig out the Field Remedy (Vx solutions to known problems) for you. It will show whcih years/VIN numbers are affected.
    HTH
    It was me Duncan, and your right, the instument cluster will need replaced, or mine did, it only affected cars from march - may 2003 I think. Reseting the service light Boris style only helps for a short period because it does not reset the oil life indicator which also triggers the service light.
    Boris, If you have to continually do yours sounds like you might have the same problem, mine drove me round the bend before I got it fixed , I had to involve VX Customer services as my dealer is as much use as a chocolate teapot ...
    I can feel my blood starting to boil just looking at the picture .....
    Quote Originally Posted by Bainie
    Ok, so Boris is partially right about resetting the service light. Does the long term solution involve taking it to the dealer and getting them to do it?
    yep, it should be fixed under warranty, does your car fall into the affected age, also there could be warranty issues if you reset your service light, they could say you should have brought it in as there is a fault & reseting the service light made it worse ! Been there mate, I would go back and don`t take no for an answer .
    North Shropshire
    I dont have to keep doing mine. I service mine to VX specs with genuine parts to keep the warranty up and keep the costs down. Just take it back for the important stuff.
    Helps When you fix cars for a living.
    Quote Originally Posted by Boris
    cheers Boris, will give it a try tomorrow
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Boris is right,
    I did mine 5000 miles ago, and not touched it since.
    Done this and it worked fine, no more spanner and oil can
  1. service indicator
    By gizmo10119 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 06:55
  2. Service indicator
    By stanian in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 23:17
  3. Service Indicator
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2007, 20:29
  4. Service indicator
    By CPHB in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2007, 14:41
  5. Service Indicator
    By Spelly in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2007, 23:04
