Thread: whats the problem with my Cdti 8v?
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Default whats the problem with my Cdti 8v?
    Right here we go,
    Car had a water leek which i had to keep topping up. Noticed the tempreture had risen to around 95c, pulled over and think i filled the water bottle up to quick and trapped some air as it was making an awful cracking sound.
    Drove about 10 miles and car went into limp mode, turned the car off and on again and it was fine, water temp was fine.
    Then started making a loud knocking noise from the engine internals, I reduced the revs to idle, It idled for 10 seconds then stopped dead.
    Left the car for about 15 minutes, went back to it, tempreture light was off the scale and i think it was the oil tempreture light was flashing away.
    Go to start the car and it seems like theres no compression.
    I called a diesel specialist, he said that the headgasket, water pump, belt needed doing along with skimming the head. And quoted me around £600-£700
    But that dosnt answer the reason for the knocking noise and no compression. I think the problems further down the block.
    Any thoughts?
    The cars only worth £2200 running so i dont know weather its worth spending the money to fix it.
    Jun 2011
    Elland
    Whataver the problems are, you need to assess the total amount of damage to the engine before doing any repairs.
    No point in throwing hundreds at the head if there's more damage elsewhere m8.
    Jul 2009
    Tamworth
    Ive been looking on ebay and i think i can get a replacement engine bare with no ancillaries for £600 so might look at doing that.
    Jun 2011
    Elland
    If there is damage other than the head, that might be the way to go m8.
    Jul 2009
    Tamworth
    Anyone else have any thoughts?
  1. Before i start tomorrow whats the common problem
    By daveypower in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 20:47
  2. Whats the problem...
    By Danwells72 in forum Diesel Engine related
    Last Post: 20th February 2009, 21:07
  3. Whats the problem?
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2008, 18:41
  4. Bulbs? whats the problem?
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2007, 23:15
