Thread: zafira locks
    wales
    Default zafira locks
    hi not sure if this is in the right section so please remove if it is.....i'm having trouble with the wifes zafira's central locking not working it only locks the drivers door.....any ideas???
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    does the boot and petrol flap work if so could be the motors themselves burnt out also check wiring into rear doors common for breaking inside tubes .
    Regular Member benny's Avatar
    Feb 2006
    dudley
    right silly question .....it only locks the door with the remote ? ...or do you mean the key actually in the door lock ? ....i would say a fuse has blown if the remote is only locking the drivers side ......if it only locks via the key beeing turned that is normal ....
    wales
    hi ...it only locks the drivers door with the key in the door. buttons on remote are not working thanks for the replys any help is appreciated
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    51 Post(s)
    Vehicle : BTCC Edtion
    Trim : SRI LEATHER
    Engine : 2.0 TURBO
    Year : 07
    Went you lock the car have you tryed turning the key again ie twist to lock twist again to lock hole car???? just an idea.
    Feb 2006
    dudley
    Quote Originally Posted by wrayballs10 View Post
    well as i said that is perfectly normal ...read the handbook ..you need a new key then to get that working but the cdl not working off the drivers door is correct it will only lock the drivers door with the key....either use the pasenger door to press the cdl button on the dash to lock it then close the pasenger door ...or use the manual door lock function ....it is all there in the hand book ......and ill add again the only problem you have is a faulty key ...!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you tried resetting the key to the car? put key in ignition and turn on but dont start engine, push one of the buttons on the key fob the doorlocks should lock then unlock the key is then reset to the car. the key in the door lock will only unlock/lock the drivers door only
  1. Scotch locks
    By marc vectra sri in forum General Chat
    Last Post: 25th June 2012, 22:36
  2. Car locks but won,t unlock?
    By the_wave_rider in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 10:38
  3. open all locks
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2008, 23:25
  4. car locks on its own
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 16:00
  5. Door Locks
    By cant stand honda's in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2008, 18:41
