Thread: CDTi Owners
    Aug 2010
    Derbyshire
    Default CDTi Owners
    Got CDTI 150 engine and done all the cleaning of throttle body, EGR, boost sensor etc....Sprayed EGR 3 cleaner into the inlet also etc, etc.
    Now everything is running smoothly, good MPG figures but still I feel it's just sluggish below 1500rpm.
    So today I've taken a look at the the vac pipes and all hoses, everything looks airtight and ok.
    Now I've also checked the swirl flap bar and that's even intact (still attached) and working ok. But.....I squirted some EGR cleaner down onto it and got some bubbling from the far right one. Now it's obviously leaking there, so would that cause it to be sluggish, and can I fix the leak on it?
    Also I want get at the swirl bar to clean things up down there it's looking a bit messy in there. So looking at the picture I've marked with a red arrow what is the fuel rail, yes. So if I remove this to gain better access to the swirl bar will I be ok to do this then replace it ok. In other words will I have problems then getting fuel back into it again to get started. I've read they are pigs to get the fuel going again.
    Cheers for any replies.
    Mick
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Unfortunatly mate - its often a new EGR thats needed and not just a clean.
    I also notice that you havent had the third injector mod done - may not help being sluggish, but will rule out any lumpy running etc.
    Nov 2010
    doncaster
    third injector mod ??????
    Engine : 1.9 CDTi
    Replacement plug/loom
    Have a look in the guides section.
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by fjaimo10 View Post
    Here you go m8
    http://www.vectra-c.com/forum/showthread.php?t=73584
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Mileage : 140000
    Aug 2010
    Derbyshire
    So will removing the fuel rail, then refitting cause me problems with getting started again? re 1st post.
    Mick
  1. Cdti Owners - look at this pic
    By Leemarksmith in forum Diesel Engine related
    Last Post: 10th December 2012, 15:02
  2. Insignia CDTI 130 owners
    By Vaux-Man-G in forum Insignia car chat
    Last Post: 25th August 2012, 07:27
  3. CDTi owners help
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 20:27
  4. +1 to the 1.9 CDTi SRi Owners
    By CHRISRi in forum Introduce yourself.
    Last Post: 4th August 2008, 07:33
  5. 150 CDTI Owners help
    By leeds vectra in forum Engine & Drivetrain
    Last Post: 3rd November 2006, 11:13
