Thread: P0704 Error
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    Default P0704 Error
    Just put a code reader on my 1.8 LS 2003, and it came back with code P0704 pending. Noticed when I started it, before even moving off it juddered and cut out.
    Having googled it, says its something to do with a clutch switch which is only a tenna on ebay, is it easy enough to access and fit?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Should be in troubleshooting
    Irmscher Insignia CDTI 130
    Nov 2010
    Wolverhampton
    Bigmac no offence all good and well moving my post but then no one see's it?
    Clutch switch is part of the cruise control circuit and if the cruise control is working you can ignore the code
    Nov 2010
    Wolverhampton
    Thanks Rapala
    Regular Member Bartekuk's Avatar
    Jul 2011
    Weymouth
    people who go on new post will see it in what ever section it is in
    Feb 2011
    Selby
    Also, 'pending' codes are ones that where the ECU has detected something not within the limits, but not serious enough to class as a fault. It could just be a one off - like you had the clutch pressed down a little bit when turning the ignition on. Or maybe a temperature sensor reads way too hot when starting the engine - but it could be because it's been sitting in the sunshine and will drop to normal once coolant is flowing.
    If the fault comes up several times in a certain time period, it'll then decide it's a proper fault, and log it as such. If it doesn't come up again after a certain time, it'll remove it from the 'pending' list.
    Pending codes are a neat system to make sure that odd glitches aren't putting the engine warning light on all the time, when there might actually be no problem at all.
    Check again in a week or so to see if it's still there.
  1. DAB box error
    By carlton in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2016, 08:55
  2. cd error
    By vicfzy in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 14:55
  3. DAB box error
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2011, 21:30
  4. P0704 (6) Clutch Switch Input Circuit Malfunction
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 28th January 2010, 11:30
