Results 1 to 10 of 11
Thread: Bulb warning light.
    Jul 2010
    Andover u.k
    Default Bulb warning light.
    Hey folks. All my lights are working just fine but for some reason I keep getting the bulb warning light along with the message saying my right fog light is out. any ideas or remedies please?
    Thank you.
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by telstar View Post
    Thank you.
    front or rear ?
    Jul 2010
    Andover u.k
    Ah good question, be right back!
    Regular Member Marcosuk's Avatar
    Fife
    does it not have a pic of the car with the bulb thats blown?
    Regular Member hagga's Avatar
    kingswinford
    I had this issue for ages on front fogs... changed bulbs and no joy... turned out to be grubby conections on bulb terminals..scrubbed with wet n dry and sorted
    Jul 2010
    Andover u.k
    Front right for now but sometimes it does say both...
    Jul 2010
    Andover u.k
    Quote Originally Posted by hagga View Post
    I will try that.
    lincolnshire
    if all bulbs are working , it can only be a connection problem
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    are they standard bulbs, or have you put led ones in? as they can cause
    "bulb out" warning due to lower current.
    Feb 2011
    Selby
    The system checks the bulbs by measuring the resistance of them (by putting a low voltage through - not enough to cause it to light up - and measuring the current that flows and comparing it with what it expects them to be.
    If you've got a blown bulb, or one about to fail, the resistance increases (infinite if it's blown, obviously). So if you've got dirty or corroded connections, that'll increase the resistance and so may put it just over the point where it decides it's too high.
    With the front fogs, chances are water's got in and corroded things. Take out the bulbs and give everything a good cleanup with fine sandpaper.
  1. bulb warning light
    By woodze in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 12:24
  2. Bulb Warning Light...
    By Ross-SRi in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 20:49
  3. Bulb warning light
    By corm in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2011, 19:03
  4. Bulb warning light
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 00:13
  5. bulb warning light
    By nufckev in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2008, 20:29
vectra cdti 150 bulb warning light
