View Poll Results: Should I swap my Signum for another car?
Voters
16. You may not vote on this poll
  • Yes, go for the Vectra
    8 50.00%
  • No, keep the Signum
    3 18.75%
  • No, keep the Signum and replace all that's broken
    3 18.75%
  • Yes, but get something else, not a Vx/Opel 3.0CDTi
    2 12.50%
Results 1 to 10 of 11
Thread: Should I swap my Signum for another car?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Should I swap my Signum for another car?
    The Signum is aging quickly. Now at 224500km (bought at 163700km last March, genuine mileage is a bit higher) it's starting to show its mileage. CV joints might need doing soon, fuel pump is probably on its last legs too. The flywheel is long overdue a replacement and so is one or more of the pulleys (aux belt)
    I recently replaced the steering column which cost me 550€, I replaced the injectors 5 months ago at 600€, renewed the front wishbones, drop links, tie rods and tie rod ends, the banana like stuff at the rear...etc. It's a car I know but I'm not 100% certain it will hold until the next cambelt change.
    Forgot to add, that I also replaced all the discs and pads a few months ago.
    Thinking of swapping it for a Vectra Estate 3.0CDTi Elite, facelift this time, with more than half the mileage. Would have to pay a bit more...but is it worth it in your opinion?
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    i think as the car get older then the costs envolved to keep it running sometimes outway the cost of the vehicle.
    as they say its your money but if it was me i'd probably change, i havent taken a car much past 120k miles before moving it on
    Jun 2011
    Elland
    So hard to decide what's the 'right' move... Nobody likes throwing good money after bad, but there's always the "if I just fix this, then I might get another year".
    I don't believe there's a right answer... but might be worth considering...
    Over here, the 1.9 is 'take your pick' in the adverts. Company car tax would have killed the V6, so there are only a handful for sale. As you know, the 1.9 is tuneable to at least the stock output of the V6 and should get you 10 miles further on each gallon. Issues with the 1.9 are well documented here and relatively easy to do some preventative work if you are buying a quite new car.
    Personally I prefer the Signum over the Vectra estate. However if you do not need the estate space, you can get a lot of Vectra for your money. Here about £5k can get you a 2007 1.9 150 Vectra with 50,000 miles on. Looked after, there should be a good 100,000 in the car...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    I think abit what triple said sometimes you paying more then its worth to keep a car going
    Voted vectra a little lighter so a little more mpg and faster
    Mar 2007
    GB
    hmm.. you've spent a lot on it recently.
    i'd keep it a bit longer to get some use out of the money that's been spent on injectors etc. with that high mileage the sale value will obviously be quite low -- i'd maybe change it in 6+ months or so.
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    I think it might be worth swapping. It sounds like the signum is becoming a bit of a money pit. May be worth cutting your losses and changing it IMHO
    May 2011
    bispham, blackpool
    get rid and get a lower milage vec once you start paying out it never ends
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by 6009tristanb View Post
    Find me one with GENUINE low mileage
    May 2011
    bispham, blackpool
    Quote Originally Posted by Celes View Post
    wow see what you mean just typed in Vectra Estate 3.0CDTi Elite and theirs one with that spec on fleybay in the uk with 149000km or 90k miles in english so god knows what its like near you to find one
    just in case you want to jump on a plane to get it http://www.ebay.co.uk/itm/2005-55-Va...item45f99af5d2 lol
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Ah mate if only we drove on the wrong side too...I'd be in a british Vec tomorrow lol
  1. Signum rear seat swap?
    By Paul_O in forum Bodywork & Interior
    Last Post: 23rd September 2010, 22:21
  2. Swap mono screen for colour in Signum
    By peterc2609 in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 13:30
