Results 1 to 10 of 11
Thread: Bilstein B8s with PI 45mm
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Default Bilstein B8s with PI 45mm
    Right almost there now....Will these be ok together? will i get any issues being 45mm with 19s? while im having these fitted is there anything else that needs to be changed?
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    think it will be **** hot mate...........good combination
    Cheshire
    http://www.vectra-c.com/forum/showth...=127768&page=8
    This guy found that they bottomed out when fully settled! and as you can read he wasn't happy with the nose down stance.
    Also when i ordered B8's I recieved B6's without any comment from the supplier! He told me he couldn't get the B8........which are the same bar the travel! make sure you read the label................. B6's are superb anyway
    Regular Member Bartekuk's Avatar
    Jul 2011
    Weymouth
    will look really nice post some pics when you're done
    Aug 2010
    Quote Originally Posted by paul667 View Post
    Lets hope there ok lol on the case of receiving B6s where was this from?
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Been running this setup for about 9 month with no problems althought can be a bit harsh at times with the state of the roads! but handles as if on rails
    Cheshire
    Quote Originally Posted by johnnyboy1985 View Post
    Europerformance they claimed that Bilstein would not supply me the B8,
    which is normal for the B12 kit.
    http://www.europerformance.co.uk/pag...oduct=15310300
    as it happens the B6 length was not a problem, and the valving is the same!
    Aug 2010
    Im ordering mine from larkspeed and venom motorsport so shouldnt have this problem.
    What else could do with upgrading?
    Cheshire
    my top link on the rear suspension needed doing but i just fitted new std ones, i put yellow stuff pads in [but there is not much choice for the 314 brakes] and braided hoses. I uprated the brake fluid. I also bought eibach camber bolts to try and get 1 deg neg on the front.
    If you check my threads you will see it is quite effective. I think the bilsteins are perfect, amazing control.
    If you want trolly jack ride you will be dissapointed.
    i run 8" wide wheels!
    Aug 2010
    I have fitted 314mms and redstuff pads awhile ago..what braided hoses did you use? notice any difference?
  1. lowering 45mm
    By ross4705 in forum Handling & Braking
    Last Post: 20th January 2011, 17:06
  2. 19s on a 45mm drop
    By chris167 in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2010, 16:30
  3. will 45mm be low enough
    By jay6392 in forum Suspension, Wheels & Brakes
    Last Post: 5th September 2010, 19:39
  4. Pi 45mm springs
    By Fig-sri in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2010, 11:08
  5. 30mm or 45mm
    By stubopvectra in forum Handling & Braking
    Last Post: 3rd March 2008, 19:31
