Results 1 to 10 of 30
Thread: 1500 bill for CDTI
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    StatsVehicle Info
    Default 1500 bill for CDTI
    Ok been having a few problems recently with the cdti 150.
    Had the car at dealer today and diagnostics check. The following needs to be done:
    Cambelt change 278.64
    Rear bushes 136.36
    Front brake pads/discs 146.34
    EGR valve replacement 195.00
    Glowplugs 95.50
    Inlet manifold 666.69
    So am getting them to do bushes as that is driving me mad, going to have to get them at some point to do inlet and save up.
    Surely I could get brake pads/discs done cheaper, as well as glowplugs. Do I also really need a new cambelt? This along with water pump was done 15000 miles ago. Any help is much appreciated.
    Admin & Server Techy Ian-Highlander's Avatar
    Ely, Cambridgeshire
    53 Post(s)
    StatsVehicle Info
    53 Post(s)
    Disks and pads will cost you less than half that to buy and you can fit them yourself (remember to borrow or buy a wind back tool for the rears).
    Which rear bushes? if it's the rear upper control arms, again these can be done easily enough yourself, they're fiddly but only two bolts (just a sod to get to one of them).
    Glowplugs you can change yourself easily.
    That'll save you a fair bit of the labour and the over priced parts cost.
    StatsVehicle Info
    Quote Originally Posted by ONEMINUTESILENCE View Post
    Rear bushes 136.36
    Glowplugs 95.50
    Ian beat me too it lol
    think there trying it on to be honest
    what rear bushes are they ??????
    cambelt doesnt need doing if last one was only 15000 miles ago
    front pads and discs about 80 fitted
    EGR valve about 100 fitted
    inlet manifold is about 180 for part and should be able to get it fitted for about 150ish
    so id tell them to stick it where the sun dont shine and go to an independant garage and ask them for a quote
    Ely, Cambridgeshire
    53 Post(s)
    StatsVehicle Info
    53 Post(s)
    If you weren't so far away I'd do the fitting work for you for the disks/pads/upper control arms etc, but you'd probably spend the difference driving down here and back lol
    Regular Member Jezzy's Avatar
    S.E
    StatsVehicle Info
    You've mentioned "dealer", do you mean a main dealer? There's very little on that list that any run of the mill independent garage wouldn't be happy to do, and much of it can be done by a DIY hobbyist/mechanic, so unless you're trying to win a game of "look who can get the highest quote", you're throwing money away.
    Get yourself trade club membership from this site and you can save even more, for example: front brake pads and disks for your car, bought from Vauxhall - 53.29 + VAT (P/N 93186297)
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    StatsVehicle Info
    maybe there telling you of the cambelt because mileage wise it is coming up to the recommended interval, but not aware you have had it done early? definitely wont need doing if only done 15k ago
    Are you VXR Enough
    13 Post(s)
    StatsVehicle Info
    13 Post(s)
    As mark says fella they are trying it on the discs and pads and glow plugs rear bushes u can do yourself
    Regular Member coooky's Avatar
    May 2011
    washington
    StatsVehicle Info
    just had my back discs and pads done 70 fitted
    inlet manifold 160 on e-bay 8 postage
    cambelt kit 80 and get it done with the inlet manifold as the cover comes of when changing the manifold also get a water pump fitted at the same time 38 e-bay
    egr valve 98 we-bay fit it yourself
    glow plugs around 30-40
    Feb 2011
    North East
    StatsVehicle Info
    Quote Originally Posted by coooky View Post
    Where was this coooky?
    Did you buy the disks / pads yourself as I was thinking of grabbing some from ebay and getting someone I know local to fit. Would work out similar...
    scottish region
    StatsVehicle Info
    I got my Egr for 120 fitted mate
  1. 1.9 CDTI 8v 1500 rpm MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 26th August 2012, 10:34
  2. CDTI jerking between 1500-2500rpm. Remedy ??
    By lesj in forum Engine & Drivetrain
    Last Post: 25th August 2012, 13:59
  3. HELP, noise at 1500 rpm
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 18th May 2012, 02:34
  4. 1.9 cdti 120 difficult to start and low power under 1500 revs
    By johninthetoon in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 07:46
  5. Juddering @ 1500 rpm
    By big nath in forum Engine & Drivetrain
    Last Post: 13th January 2010, 23:32
