Results 1 to 10 of 11
Thread: Turbo banjo bolt
    May 2011
    lancs
    Default Turbo banjo bolt
    Hi All, I know when replacing the turbo your supposed to replace the banjo bolt and copper washers, My question is is'nt there 2 banjo bolts? one on cylinder block and one on the turbo, Do i change them both? Thanks
    Feb 2011
    Selby
    Depends if you undid both...
    May 2011
    lancs
    well i've undone the one off the engine block to remove the turbo, But everyone states replace banjo bolt but theres one on the engine block and one on the turbo, Just wondering as everyone states banjo bolt or do they mean the pipe? Thanks
    Feb 2011
    Selby
    Normally with banjo bolts in general, you just need to replace the copper washers on either side of the banjo. These crush when you tighten the bolt up to form a seal, and are likely to leak if you reuse them.
    Having said that, I've had banjo bolts on and off brake calipers and turbos many times over the years and only occasionally had a leak. Often if you just heat the copper washers up with a blowtorch until they glow, then let them cool slowly, they'll have softened enough to seal properly again.
    May 2011
    lancs
    Thanks rich i know the banjo bolts have a little filter in them which is what gets blocked over time and blows the turbo But what i'm trying to get my head round is how do the holes on the bolt line up with the hole in the pipe i'm assuming it's all down to the design of the threads on hole/bolt
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    the bolt is machined to allow oil to pass the full circle of the bolt.
    Feb 2011
    Selby
    The banjo has a groove all the way round it's inside. The bolt that goes through the middle is hollow, and has a hole (or holes depending on it's size) that line up with the groove. So oil/coolant/brake fluid can pass from the pipe on the banjo through into the bolt and into whatever it's screwed into.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Only the Bolt into the engine block has a filter on the 1.9CDTI, so I'd only be changing that one. I did three turbo changes on the same one last weekend though with no issues.
    May 2011
    lancs
    Cheers all for replies, Nutron did you replace all disturbed gaskets for new ones. Thanks Tommy
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Umm....no. I have changed turbos five times in the last two weeks, I'd be broke by now if I did.
  1. Power Steering Banjo bolt size
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2013, 12:32
  2. Banjo bolt size?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2011, 20:59
  3. Banjo washer size?
    By rushy in forum Handling & Braking
    Last Post: 14th January 2011, 15:06
  4. Brake banjo sizes
    By installer in forum Handling & Braking
    Last Post: 19th June 2009, 22:16
  5. CDTI Banjo Bolt
    By JamesG in forum Engine & Drivetrain
    Last Post: 1st February 2008, 14:17
size for banjo brake nut vectra c
vectra c brake banjo
Vectra 1.9 cdti banjo bolt
1.9cdti banjo bolt
