Results 1 to 2 of 2
Thread: Boost control with actuator arm
    Worksop
    Default Boost control with actuator arm
    Can u manually adjust with alterin the actuator arm on a z20net
    WGAF#5
    yes you can ....
    but the question is why do you need to ..
    you can reduce and increase boost by altering it but too much or too little can have a detremental affect ... its ok for a short term fix whilst your diagnosing but i wouldnt leave it too long .
    loosen the retaining nut then you pop off the little circlip on the end of the arm (dont loose it!) and then wind in / out full 360 degree turns and refit the clip and tighten the nut back up .... be warned that when the engine is HOT the arm will be VERY HOT.
    remember to record somewhere how many turns you have made ...as you will need to return it to "standard" when you have finished checking /repairing the cause..
    but if your still having issues with boost following the replacement of the soleniod valves and checking the hoses i think i did already say you needed the integrated recirc dump valve repair kit vx part no 55558271 to resolve the issue
    regards
    Dez
  1. boost control solenoid
    By viper8 in forum Engine & Drivetrain
    Last Post: 14th January 2013, 00:22
  2. boost control solenoid
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 13:45
  3. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  4. Turned boost up actuator rod 2.0t
    By vectrasri20t in forum Petrol Engine related
    Last Post: 30th January 2010, 18:19
