View Poll Results: what to do wheel wise???
Voters
9. You may not vote on this poll
  • sort audi 19's
    2 22.22%
  • hold out for 20" n refurb others
    1 11.11%
  • get some 18's
    5 55.56%
  • other... please advise
    1 11.11%
Results 1 to 10 of 11
Thread: wheel size???
    Regular Member hagga's Avatar
    kingswinford
    Default wheel size???
    Evening Peeps ... I'm in a bit of a dialemma about what to do about wheels.. the problem i've got is that at present I'm running 19" audi rims but getting vibration through the front.... I believe this is possibly down to cr@p machining of the spigot hole (not quite centre)...these replaced the 20" rs futura rims I had until I killed one and couldn't get another... now realy want to sort this issue and been pondering about going back to 18's as I'm now working on just making my car quicker and handle.....what would you do...
    1, Sort audi rims?(get checked/spigots rebored and adapters to suit)
    2, Hold out for another 20" rim and get others refurbed?
    3, get some 18's (maybe the cheaper option)
    4, other...(please advise)
    Engine : 1.9 CDTi
    Get the Audi ones sorted.
    Its good to see something different on a Vectra
    Jan 2010
    glasgow
    the audi rims i take it your using wobble bolts id keep the audi rims and get adapters made up
    kingswinford
    Quote Originally Posted by lee gsi View Post
    This is an option... when I had them machined I couldn't find anywhere with a lathe big enough so had the done on a radial miller..anyone who knows about machining will know the lathe would have been a better option... anyone know of any good machine shops around mids/shropshire that can handle this?..I have thought about getting some audi copy rims with correct spigot wotsit... but they're pricey... don't get me wrong..I'm not tight.. but my 20's cost 2k with tyres and are basically scrap as i cant get another.. audi rims n tyres cost £385 off ebay+£160 machining+£40 tyres removed/refitted n balanced.... just want to get things sorted
    Cheshire
    [QUOTE=hagga;1583930]Evening Peeps ... I'm in a bit of a dialemma about what to do about wheels.. the problem .................................I'm now working on just making my car quicker and handle.....what would you do...
    QUOTE]
    Well you won't like the answer but for speed round corners and handling you require 8" wide 18" dia pro race 1.2's (or other special light wheels) at 10kg ea which is best part of 5kg lighter than your 20" perhaps more! Then buy a decent 235/40x18" tyre zeronero or pilot, I have gone for track biased tyre Federal 595 RS. Lower profile rubber is known to be inferior for handle, although the roadholding should be a bit better. I know my car is transformed with lighter wheels.
    kingswinford
    Quote Originally Posted by hoochydady View Post
    i am using wobble bolts but had to get spigots machined out to 73mm(using 73-65 i think).. but think the machining was out a lil..
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    [QUOTE=paul667;1583952]
    Quote Originally Posted by hagga View Post
    QUOTE]
    as above or even go for the 17's like the btcc teams do with massive positive camber on the rears....
    Midlands Mod Shop - NFFC.
    kingswinford
    QUOTE]
    ok i'm not after mega handling/road holding... but something decent.. i ran 18's with khumos which i believe gave a good allround balance... my present 19's have 'sunnys' up front and avon rears (not my choice but what they came with) (sunnys are a lil ropey in wet).. my 20's had conti's at £250 a corner and those were the ones when my back end slid out and took a short exit into a wall lol... i can get equal road holding with each set up (18,19 or 20") but dunno what to go for as in sort rims i have(19's and 20's) or just get new 18's..
    kingswinford
    [QUOTE=ditchp;1583966]
    Quote Originally Posted by paul667 View Post
    cant go to 17's as i've got 360mm discs upfront
    Cheshire
    Top in = Negative camber
  1. wheel nut size
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2012, 08:26
  2. wheel size
    By booner in forum South Central (ARO - matty2fatty)
    Last Post: 16th February 2012, 23:32
  3. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  4. sri wheel size
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 18:33
  5. Wheel size 2.2 DTI
    By Haris in forum Styling
    Last Post: 12th July 2009, 18:25
