Results 1 to 10 of 14
Thread: Removing a tow bar?
    Regular Member bigdave1701's Avatar
    York
    Default Removing a tow bar?
    Is it just a simple case of taking a socket set to the bolts and unplugging any wires or is there some tech2 work involved?
    newcastle
    cant help you im afraid but removing the tow bar from my old 2.2 was a right pain.
    couldnt remove it myself and in the end took it to my local independant who also couldnt couldnt remove it - he eventually got it off with a grinder.
    after that i had a permanant airbag warning light on the dash
    May 2011
    bispham, blackpool
    which type is it my towbar is a removable one with the electrics under the car all i have done is removed the swan neck ball and left electrics under the car on its own baracket
    if its a permenant towbar one take it off and disconect electrics and thread the electrics back in to the boot and then reconect it and leave it in the boot only you will know its their and it will save you getting the towbar turned off by tech 2
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    If its the VX towbar electrics with tailor module and you not keeping it, give me a shout I may have if off you if the price is right, and if it will fit a preface?
    Oct 2010
    Walkden, Manchester
    Quote Originally Posted by Jonsey View Post
    Canx that just got some off ebay.
    The towbar only has 4 bolts in it which can be accessed from the boot, when I had mine fitted there was no need to take bumper off..
    York
    It looks like this ifthats any help:
    Oct 2010
    Walkden, Manchester
    thats a fixed flange one by the looks of it, same as mine, as for the electrics your best looking in the cubbyhole to see if you can see either the VX wiring into the REC or a 7 way bypass relay prob below the rear light cluster. looks like below.
    If its the VX wiring I cant see it being a prob, just unplug it and see if anything appears on the display if not your fine.
    if its the bypass relay, just take it out no possibility of errors.
    York
    Cheers.
    I collect the car wed/thurs next week so will either ask them to remove it before I take the car or have a poke around next weekend.
    Oct 2010
    Walkden, Manchester
    Its quite easy taking if off, If I knew how easy it was before I had mine fitted I would of done it myself and saved over £120. its literally 4 bolts that hold it in the boot floor, with a stiffening plate either side. I can try and get some pics of the boot interior later on if you want.
    York
    If it's just 4 bolts I'll do it myself then.
  1. OP-COM for removing EGR
    By Paul_NI in forum Northern Ireland (RO - Vacant)
    Last Post: 17th September 2012, 19:26
  2. removing wax
    By forde in forum Detailing and Car Care Discussion
    Last Post: 21st March 2012, 08:17
  3. Wax Removing
    By Wolflinn in forum Detailing and Car Care Discussion
    Last Post: 10th March 2011, 09:33
  4. Tip For Removing...
    By AntB in forum Detailing and Car Care Discussion
    Last Post: 10th August 2009, 17:36
  5. Removing the egr !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 17:53
