Hey up peeps
Looking for a twin rear system for my gsi as mine has the diesel 1s put on for the mot and then sold
I have found a cat back system but it's off a 1.8 sri am I correct here
That the twin exhaust systems are all exactly the same
Hey up peeps
Depends on age of 1.8 sri, mines 57 plate (vvt) 40mm dia standard pipe,2.2 is 45mm, would thought gsi would 45mm or more. Now have full cat back powerflow system 50mm fitted.
It's off a 2003 mines a 2002
if dia is to small then it will restrict gas flow, check yours first at down pipe, what is dia off system you've found.
got a link for the sri one, if its no good for you others may be interested
i have been looking at getting mine decatted on other threads on here it says to replace the cat with a 63mm pipe if thats the case is the whole system 63mm or is it just the front pipe
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_1026wt_689
There is the link just asked him for the diameter of it and will take mine off tomorrow and check hope it is only need the back boxes
Ano lad only want the back boxes as my gsi has the diesel 1s on an old mad had mine and he put them on for the mot and the look awefull
Just been under mine and it looks exactly the same even down to the middle pipe befor centre box length hope to god it is coz I will buy it
