Results 1 to 3 of 3
Thread: VectraC 2.2dtr "misfiring" when cold
    Jun 2011
    maidenhead
    Question VectraC 2.2dtr "misfiring" when cold
    This one has me baffled. Car starts fine, idles fine, never misses a beat when warmed up. But oh dear when first started I can increse revs (gently to about 1500 to 2000 and it will misfire very badly, revs dropping right back, smoke, everything. Been through pipes, turbo egr throttle etc., everything and no apparent mechanical fault. I discovered that unplugging the ECU engine temp sensor (replaced just in case) fools the engine into thinking its hot and it will run perfectly even though its really cold, problem is the ecu thinks the engine is hot and so the cooling fans run full tilt all the time.
    I can only think this is an ecu program mismap. Anyone else experienced this or have any suggestions as it's most embarrasing to drive 1st thing in the morning?
    Jul 2011
    poland
    Default Sensor elobau
    I think you have problem with sensor elobau and throttle.
    I repair this think, sensors and all cars electronics
    You must check on the computers.
    Can be errors p0638 or p1125
    Jun 2011
    Dunfermline
  1. Funny "TICKING" Sound when cold
    By JonnySRI in forum Engine & Drivetrain
    Last Post: 5th February 2013, 00:39
  2. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. "Cold Turkey"
    By Happy Girl in forum The 'Off Topic' room
    Last Post: 14th December 2008, 17:35
  5. "Man Cold"
    By Caterman in forum Comedy & Humour
    Last Post: 19th November 2008, 05:37
