Thread: rattling rear pads on my old veccy B
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Question rattling rear pads on my old veccy B
    I recently changed the rear pads on my old veccy B, I also fitted new retaining pins, spring clips and I copper greased the back of the pads.
    However the pads now rattle around in the calipers making an awful noise but obviously are fine under braking. I took them out and smeared on a healthy amount of extra copper grease but this has not resolved the issue..
    I have searched the other relevant vec sites but have found no solution to this, people have had the same issue but have ended the threads with useless posts like 'all sorted now' without explaining what they did the resolve the problem..
    I know some of you have had Vec B cars in the past, can anybody remember having this problem and what they did to fix it? I would like to fix this on saturday as I will be doing the rear ARBs as well...
    Any ideas?
    Glasgow
    Cheap pads or vauxhall pads? If its not vauxhall pads theres your cause they are not a perfect fit.
    Birmingham
    Bleed the brakes mate, shoudl help. Also, check the caliper bolts (if they were opened).
    This was happeneing on mine last week and drove me round the bend trying to suss it out, fortunately for me it was just the pad spring. New one fitted and perfect.
    Bye bye Vec B
    - Hello Siggy!
    Jun 2009
    South Coast
    They are not gm pads but that's never been an issue on other cars, I will have a fiddle with the spring clip to see if I can mod it and make it a tighter fit.
    Brakes were fully bled at the time I changed pads. Its defo the pads rattling
    Glasgow
    Quote Originally Posted by Caveman_nige View Post
    It can be an issue when you dont use original equipment especially brake pads ive had experience of it at work and on my old gsi when i first bought it and the dealer had fitted cheapo brake pads instead of original vauxhall ones to save a few bob, if the pad is rattling or clunking and everything is tight including the spring then its the pads being a bad fit. An example is copy body panels now some of them you would think are'nt even designed for the car you have bought them for
    Jun 2009
    South Coast
    cheers for the info.. will have to give vx a ring and see how much a set is at trade...
    Birmingham
    Im sure I paid about £21 trade for mine about 2 months ago.
    Bye bye Vec B
    - Hello Siggy!
  1. Rear pads rattling like a MF
    By TerrySRIV6 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 20:17
  2. Rattling rear pads
    By tomo41 in forum Suspension, Wheels & Brakes
    Last Post: 22nd August 2011, 14:55
  3. Rattling from Rear
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 17th September 2010, 20:29
  4. Rattling rear hub
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2009, 16:06
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
rattling rear brake pads on a vectra c www.vectra-c.com
