Results 1 to 10 of 15
Thread: Big Brake Kit...
    spoons
    Guest
    Default Big Brake Kit...
    Well I thought my front brakes were big at 362mm and AP Racing 6-Pot calipers needing 18" wheels minimum to fit.
    But Regal now have a BIGGER brake kit ready for the Vauxhall Range.
    390 mm 6-Pot kits same as used on the Audi V10 R8 and RS6
    http://www.vxronline.co.uk/forum/sho...9-NEXT-upgrade
    http://www.regal-shop.co.uk/vauxhall...CS_Brakes.html
    £2,139.58 if you're interested and you will need 19" wheels minimum
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    Saw them in TV a few issues ago, sweet
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    You getting them on order Spoons?
    Regular Member hagga's Avatar
    kingswinford
    Quote Originally Posted by spoons View Post
    mine are only 360mm. Hispec do a 400mm disc and have the pattern for the vec c brackets... they must be huge
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    What kit are you running hagga? My 314's just look crap beneath the 19" rims.
    kingswinford
    Quote Originally Posted by Vectra_C_Chris View Post
    hispec 6pot front/4pot rear... not as good as mr spoons's but a little cheaper.
    spoons
    Guest
    Quote Originally Posted by hagga View Post
    I'm still using standard issue single pot rear calipers with standard pads No luxury 4 pot rears for me
    Next year I think I'll be changing the discs on mine as they are 3 years old now and worn a bit. Luckily I can just unbolt the bells, and change the rotary discs. Which helps keep the costs down
    kingswinford
    how you find they're wearing? I know you do a lil more track stuff than me but mine have worn very well.. I had to change the fronts as I'd warped one when I'd wrote my car off but even after 2 1/2 years they'd still got loads of meat left..my rears are 325mm and by the looks of the wear they'll out last the car lol...I like the fact that the front pads(red stuff(aston martin/tvr)) are cheaper than red stuff gsi pads lol.
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    No it doesn't... ;>
    spoons
    Guest
    Quote Originally Posted by In a states View Post
    No it doesn't... ;>
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. brake help please
    By sristeven1 in forum Suspension, Wheels & Brakes
    Last Post: 20th September 2010, 18:30
  4. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  5. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
