Thread: Tow starting the correct way
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default Tow starting the correct way
    Hi again guys. Long time no see.
    Well after nearly 3 weeks away on holiday and not been driven, my beloved has drained all the diesel back to the tank and there isn't enough juice in the battery to get it going without a booster or a car to jump from. Neither of which I have so tow start it is.
    Going on what others have said, and from what I remember, get it somewhere open, second gear with the clutch engaged and pull, then eventually it will cough into life? Any recommended speed to do it at?
    Cheers.
    Quote Originally Posted by cont1204 View Post
    Cheers.
    no ...... sit in car with ignition on , car in 2nd and clutch pedal held down ,
    when car starts to get towed , only need to be going about 5-10 mph , lift clutch and rev at the same time then dip clutch back down
    hopefully this would have started it if not just keep repeating it till it does
    West
    As above
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    When you say rev, what do you mean? Let the clutch out so the engine revs up then as soon as it has, clutch down again or let it out and leave it there, then back in?
    West
    let the clutch out, & start to press the accelerator... Don't ram the towing vehicle mind, once the motor has fired up press the clutch back in & rev the engine a little
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Cheers guys.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    All done. Beloved lives once again.
  1. Is this the correct Kit?
    By Vectra Dan SRi in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2013, 00:07
  2. These the correct ones?
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2012, 03:06
  3. Correct oil?
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 10:23
  4. is this correct
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 14:15
  5. correct oil
    By Dougb in forum Engine & Drivetrain
    Last Post: 27th April 2010, 14:27
