Thread: Is this the DMF
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Is this the DMF
    Hi all not long had the Vectra its a 2.0T with 45000 on the clock when idleing i can hear a faint rattle coming from the centre console only very slight when putting my ear on the gear stick its coming through the drive train when i press the clutch it goes away does this also affect start up as mine seeems to start up quite lumpy but starts first time every time and drives perfect
    Jun 2011
    Herts
    sounds like it..............
    Regular Member C-Owner's Avatar
    May 2011
    South London
    No thats probally the clutch bearing
    The DMF sounds worse when the clutch is pressed, but rattles like this on idle.
    "This is a short video so you can hear what the dreaded Vectra C Dual Mass Flywheel (DMF) rattle sounds like.
    The video starts with no rattle (except for the normal engine noise).
    About 5 seconds in you can hear me say "Now", at which point the clutch is pressed down and you can hear the banging/rattling noise start."
    http://youtu.be/DIfiHkUAgWc
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Your right it's only the release bearing I'll get it done as soon as will do clutch at same time would it also affect 1st gear into 2nd it isn't as smooth as I like
    Regular Member PORKBALLS29's Avatar
    Epping
    It may help but the f40 gear box is renowned for having notchy 1st to 2nd.
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Mines exactly the same! only noticed it the other day seems to be louder when cold too. Sometimes can't even hear it when been on a long run
    Is it a big job changing clutch bearing? what will happen if its left?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by benholden2010 View Post
    Im not sure what will happen if left but it wont be long till i have it done ill let you know how big a job it is and how much it costs
    lincolnshire
    its the same as swapping out the clutch , gearbox off , subframe dropped etc a pain in the harris , in other words !
    May 2011
    South London
    Clutch release bearings can get really noisy before they need changing.
    http://www.youtube.com/watch?v=gdVJ5vnO6Jg
    Best to have the clutch assembly inspected as the bearing can be replaced cheaply but its a case of seeing what else is worn at the same time.
    Some of the older gearboxes had inspection holes, greasing up release bearings was common practise, (blob of grease and a long screw driver or spray grease if you were lucky), if they got rattly.
    Sorry for the vid's but its the best way to get the point across I think
