Thread: Fuse rating and take off for TA and AUX
    Engine : 1.9 CDTi
    Default Fuse rating and take off for TA and AUX
    I am in the middle of retro fitting a Travel Assistant and extra Aux socket in the rear of my Signum.
    I need to take off 2 ignition switched live's.
    What fuse's are needed for each item I am adding and what fuse location should I take the ignition live's from?
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Sorry lee only just seen your post
    Just had a quick read of the HOW-TO and I guess the fuse rating for the TA is:-
    take out the 25a fuse from F26, place the fuse in the red cable fuse holder, add the supplied 20a fuse to the holder and then plug back into way F26
    So I'm guessing F26 is replaced with a 20a fuse but the 25a one that was removed was installed in line to the TA so it is double fused in the live going to fuse F26
    Well thats what I can make of it
    Incase you've not come across the HOW-TO:- http://www.vectra-c.com/forum/showthread.php?t=15099
    Hope it helps
    Damo
    Engine : 1.9 CDTi
    Yeah I wasnt sure what fuse ended up as the TA fuse.
    Any idea where the Aux socket (And fuse rating) is taken from?
    Year : 55
    Mileage : 92,000
    Have heard mention that some have wired their AUX socket to the rear cigarette lighter
    Or as Duncan did and installed a permanent live in the boot
    http://www.vectra-c.com/forum/showthread.php?t=11536
    Engine : 1.9 CDTi
    Dont really want to be running more wires to the rear cigarette socket and not wanting a permanent live socket (I will probably leave something plugged in and drain the battery lol)
    Engine : 1.9 CDTi
    Engine : 1.9 CDTi
    Gong to take the power from Fuse 26 as per HOW2 but what fuse should I use for the Aux socket?
    Engine : 1.9 CDTi
    Anyone have an idea?
    Engine : 1.9 CDTi
    Decided in fuse 15 or 16 as they are rated at 15Amp for heated front seats and I dont have them (Even though there is a fuse fitted)
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  3. 3.0 v6 cdti rating??
    By vt3ccrx in forum Diesel Engine related
    Last Post: 18th December 2009, 23:03
  4. Amplifier Rating
    By siz1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2008, 10:46
  5. Progress Rating
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 01:11
