Thread: Emmision light problem
    Jul 2009
    Woking
    Default Emmision light problem
    Hi I have a 1.8 Vectra with a emission light staying on.code p0100 I have changed the MAF and checked for a faulty earth lead.But still have the light on.The car cuts out when cold but otherwise runs fine.Any ideas would be welcome.Regards Mike
    uk
    Hi Mike, check out erratic Revs - my 1.8 - similar problems.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't know much about this engine, but I am going say EGR valve or Throttle body is choked up if you're getting erratic revs.
    Jul 2009
    Woking
    Hi Gazza4 I dont think there is a EGR valve on a 1.8 petrol If there is I cant find it.Maybe as you say the throttle body.Is it easy to get apart? Cheers
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by flatmate View Post
    Like I say I don't know an awful and from what I gather the EGR valve was removed from later models - '04 I think. I'm basing my theory on the erratic revs which was mentioned? Is that happening?
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Check Just Under Bottom Right Of Engine Cover For EGR
    Jun 2011
    United Kingdom
    What year is he car ? If it has the egr I would give that a clean aswell as the throttle body n disconnect the battery for 30 mins or so and take it from there.
    Jul 2009
    Woking
    Hi Tam80 Looked there but there Via Haynes but nothing there.Must be later model Cheers
    Jul 2009
    Woking
    kel123 Checked your irattic revs but not same as mine thanks anyway
    Jul 2009
    Woking
    mdibb2009 Will give it a go Cheers
  1. Rear Signum Light problem problem - help
  2. Diesel exhaust emmision colour.
    By felixx in forum Engine & Drivetrain
    Last Post: 11th October 2010, 00:06
  3. Limp mode, Emmision light on
    By sirnapper in forum Engine & Drivetrain
    Last Post: 25th May 2009, 01:43
  4. Problem - ABS light is on!!
    By pamsie36 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2008, 18:16
  5. These emmision sensor things
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2008, 11:37
