Results 1 to 3 of 3
Thread: Checking MAF power Supply
    Mar 2011
    South Normanton, Debryshire
    Default Checking MAF power Supply
    Anyone know how to check the MAF sensor power supply or Voltage supply as thats what's come up and a Solus Scanner.
    And does anyone know what kind of reading i shud get when i manage to check it? my cars a 2.0DTI 54Reg
    Engine : 1.9 CDTi
    • Ignition OFF
    • Disconnect wiring harness connector from:
      B69 Air Mass Meter
    • Ignition ON
    • Measure voltage between the following terminals:
      B69 Air Mass Meter
      Wiring harness connector (wiring harness side) terminal 2
      B69 Air Mass Meter
      Wiring harness connector (wiring harness side) terminal 3
    NEEDS TO BE GREATER THAN 11v
    Then:
    B69 Air Mass Meter
    Wiring harness connector (wiring harness side) terminal 4
    B69 Air Mass Meter
    GREATER THAN 4.8v
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Maf voltage errors are normally just down to them not having the connector fitted properly. Try reseating the connector, I searched this error a while back and this was advised of this and it worked.
  1. help with power supply
    By vxr_and in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 12:21
  2. 12v power supply from boot?
    By Craig1985 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2011, 23:24
  3. Power Supply for GPS ??
    By AirCooledHeaven in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2006, 21:09
  4. Power supply
    By Robin in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2006, 13:06
