Results 1 to 10 of 14
Thread: HELP! Car wont start, Engine turns over.
    Regular Member CDTI120SXI's Avatar
    Mar 2011
    Wrexham
    Default HELP! Car wont start, Engine turns over.
    I bought a towbar for my car with the wiring kit for the vectra, in fitted the towbar and electrics as per instructions exactly.
    reconnected battery and proceeded to check the lights and immediately noticed the bulb management system light was on with fast flashing indicators suggesting a bulb is blown. All bulbs fine i unplugged all the towbar electrics so the car is like it should be.
    No alarms or lights on the dash but when i try to start the car the starter motor turns but it wont start.
    Now when i lock the car it alarms itself after only one click of the key.
    Need the car for work so im kind of panicking at the moment.
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    disconnect battery for 30mins, then give it another try.
    Mar 2011
    Wrexham
    Quote Originally Posted by dannydm1 View Post
    No luck, checked every single fuse too. I'm started to thing something much worse is broke like the ECU.
    Jan 2008
    leeds / wakefield
    you could have effected the immobilizer messing with the wiring meaning it wont fire up.... usually diconncting the battery resets the ecu....
    Mar 2011
    Wrexham
    i used a vectra specific wiring kit for the towbar, just plugs into the fusebox in the boot and i believe this has caused the problem i have now.
    Im gunna call the company tomorrow and tell them what their part has done.
    Mar 2011
    Wrexham
    completely baffled.
    its a 1.9CDTI btw
    I've noticed that when i turn the ignition on there is a clicking noise from the boot but no pump sound like normal.
    Jan 2008
    leeds / wakefield
    did you ring the company?
    Glasgow
    Sounds like the wiring is wrong and the battery has drained.
    Engine : 1.9 CDTi
    Sounds like battery to me.
    Try jump starting it.
    Mar 2011
    Wrexham
    Not yet , i have been working and im having to cycle 18miles to work leaving my house at 4am and 18miles back
    Quote Originally Posted by byebyeitsagsi View Post
    Tow-bar wiring removed completely, battery turns engine over fine but it just wont fire up.
  1. CDTi turns over but wont fire
    By Malcste in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2011, 14:40
  2. 150 1.9 engine wont start
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 21:29
  3. CDTI Engine wont start
    By dag1 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2010, 20:11
  4. Engine wont start
    By frag45 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2010, 17:16
  5. engine died wont start anymore
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2008, 17:55
