Results 1 to 10 of 25
Thread: Mounting TPMS control box?
    Engine : 1.9 CDTi
    Default Mounting TPMS control box?
    How does the TPMS control box get mounted?
    What way uo does it go (On a Signum if it makes a difference)?
    Aug 2010
    Stoke on Trent
    Mine was meant to go below the offside rear light cluster but I didnt have the mount so I've attatched it to the alarm bracket. The bracket has a mount that fits the TPMS module perfectly.... this is on a preface Vec C
    Engine : 1.9 CDTi
    Does it matter what way the mast faces?
    The Signum it goes by the nearside light cluster.
    I have made a bracket and can see where the original bracket would bolt but not sure what way up it goes.
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi lee
    the module sits upright withthe little aerial pointing upwards
    there is a bracket available from vauxhall to mount it but i just tucked mine
    in the gap were the trim pulls off to access the near side rear lamp.
    Aug 2010
    Stoke on Trent
    yep... aerial pointing up...
    Engine : 1.9 CDTi
    All in
    Just the rear loom and receiver to fit now.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Mines in Lee and Tech 2'd today but the update rate seems slow bit disappointed as the psi isn't displayed straight away takes a minute or so to come up after that its brand new just a little disappointed.
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by paulhb View Post
    I'm fairly sure this is normal.... it takes approx 5mins after setting off for my CID to display the PSI on all 4 wheels and it updates every couple of minutes (while moving) however it immediately registers any deflation outside the limits set by Tech2.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    I still want TPMS .. even thou it wont show the actually pressure in mine
    Engine : 1.9 CDTi
    At the moment I just have the front receiver fitted (as the wiring was there) and on the way to work this morning it started to register pressures. Fronts came up first then one of the rears registered somehow lol.
    Hoping to get the rear loom and receiver fitted over the weekend and then Tech2'ed so the warning pops up on the dash when the pressure gets to low.
  1. Mounting TPMS receivers?
    Last Post: 29th October 2012, 20:37
  2. Strut Top Mounting
    By baluachrach in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2012, 22:57
  3. PDA Mounting
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2007, 17:12
  4. Single DIN Mounting
    By bandrew in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2006, 01:53
