Thread: brake light
    Regular Member scottyd's Avatar
    paisley
    Default brake light
    hi guys got a problem with offside brake lights, changed bulb and cleaned connectors yet only one of them comes on and 2 on nearside, any ideas?
    11 Post(s)
    Confused.
    You should only have one brake light on each side of the car.
    Two tail lights per side. The upper is also the brake light. Should that one fail, then the lower tail light takes over the role of tail/brake light.
    Sounds like you need to double check all the bulbs are ok. Single filament 21 watt, btw.
    paisley
    yeah i know that mate thanks ive tryed about 6 bulbs!
    Regular Member rustle's Avatar
    May 2011
    Lincoln
    Same problem here does anyone have any ideas?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    As above, sure you've got the right bulbs for the circuits? If it was passenger side I'd suspect you were looking at fog light, which isn't wired as standard.
    May 2011
    Lincoln
    All sorted now one of my bulbs was about to blow, swapped for a new one & all ok
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Brake light
    By mambo in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2010, 01:36
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
