Results 1 to 2 of 2
Thread: front fog light fuse
    Aug 2010
    shropshire
    Default front fog light fuse
    hi guys and girls
    ive just brought my new vectra sri c 56 plate and the front passenger fog light was not working so checked and brought a new h3 bulb .
    the old one looked ok but i changed it anyway,now there was water inside the foglight and it still does'nt work so i'm suspecting a blown fuse.
    my question is where is the foglight fuse-is there a fuse for either side(drivers side works)
    i'm asking this as the manual does'nt mention where the fog light fuses are and that the bulb is an dealer fit only for some reason.
    many thanks in advance
    Feb 2011
    Selby
    Pretty sure there isn't a separate fuse for the foglights, and certainly not separate for left and right ones.
    So that points to a wiring fault or corrosion in the bulb holder (due to the wetness). Not at all uncommon in foglights on all kinds of cars, because by their nature they're low down and close to all the water and rubbish off the road.
    Take the bulb out and turn on the foglights, check with a voltmeter or test bulb if you have 12V between the bulb terminal wire and the bulb holder. Now test between the wire and battery negative. Finally test between battery positive and the bulb holder.
    That should should tell you if it's a problem with the supply, return, or bulb.
  1. front foglights fuse
    By jamie_hepp in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2016, 02:27
  2. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  3. Front courtesy light, fuse number
    By sirnapper in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2009, 15:41
  4. the vectra's front fuse box
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 22:54
  5. Front fog light "fuse"??
    By armoured farmer in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2006, 07:52
vectra c fog light fuse
vectra c front fog light not working
fog light fuse vectra c
vectra c front fog light fuse
vectra c 1.8 fog light fuse location
vectra c sri fog light fuse location
https:www.vectra-c.comforumshowthread.php142744-front-fog-light-fuse
vectra c front fog lights not working
vectra c 1.8 petrol foglight fuse
vecyra sri front fog light fuse
vectra c foglight fuse
1.8 vectra c fog fuse
opel astra 2010 1.6 fuse for fog lights2005 vectra foglight fuse locationis there a fuse for astra 19 deisel front fog ligtsvectra drivers side front fog light faultvauxhall signum front fog light fusevauxhall vectra c front fog lightswhere is the fuse for fog lights situated on a vauxhall vectralights on a vauxhall vectra fuses2004 vectra fog light fuse2004 vectra fog light not workinglocation of fuse for fog lamp fuse on 07 vauxhall vectrawhat is front fog light on vauxhall vectra called in fuse boxOpel astra g fog light fuse
