Thread: slight noise from engine when i turn it off ,v6 turbo
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Default slight noise from engine when i turn it off ,v6 turbo
    as above ive noticed a noise when i switch off my v6 turbo auto vec,its like something thats still spinning and seems to be coming from roughly the back offside of engine near too the pas pump reservoir,anyone any ideas what it may be ,the cars under warranty so will gewt it checked but really curious too know what it might be
    Feb 2006
    Vehicle : Audi
    Trim : A5
    bumpity bump
    My Signum used to do something like that - the AC pump was completely knackered inside and used to do it's own thing, including spinning down by itself after I'd switched off the engine...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Think that's just the A/C and climate control. Normal, if it is making a high pitched but faint whine for about 10seconds.
    Quote Originally Posted by Gazza4 View Post
    Trust me mate, it was absolutely ****ed...
    Glasgow
    Was the air con on when you switched the engine off and was it a hot day? If the answer is yes yes then don't worry its normal.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I know that the power steering pump can make a noise when you shut them off but the EHPS isn't fitted to the 2.8 is it?
    Glasgow
    No electric power steering on the 2.8 and a fluid tank you can easily top up next to the air filter.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Im thinking its a power steering prob as pas is noisy and noise is coming from that general area,will get it booked in tomorrow as its under warranty,deffo a prob and deffo nothing to do with aircon,climate system,ill keep you posted on the results mateys
    Jun 2011
    Elland
    I get a whirr-click from my v6 diesel when it's switched off... it's just the VNT actuator servo settling down to bed. Maybe something quite normal m8, but check it out if you're concerned, esp. as under warranty.
  1. Slight whining noise
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 25th March 2012, 17:54
  2. Slight Tapping Noise
    By spennny in forum Engine & Drivetrain
    Last Post: 28th March 2011, 21:03
  3. Occasional engine noise, slight rough idle, poor MPG
    By Snizzers in forum Engine & Drivetrain
    Last Post: 16th June 2010, 10:44
  4. Slight rattle noise...
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 4th July 2008, 13:22
  5. Whining Noise from 2.0L Turbo Engine?
    By pauls898 in forum Engine & Drivetrain
    Last Post: 28th April 2006, 10:13
clicking noise when i turn the engine off on 2008 vectra tdi
do all turbo diesels whirr when you turn the engine off
high pitch noise after turning of car vectra 3l v6
