Thread: Vectra - boot open indicator flashing during moving
    Oct 2006
    Midlands
    Default Vectra - boot open indicator flashing during moving
    Hi, I have a 2002 Vec C and while I'm driving my boot open indicator flashes as the car goes over bumps in the road. I have tried adjusting the catch and the garage has checked the latch but to no avail???????????
    Any Ideas...Thanks
    Regular Member Harry's Avatar
    Uxbridge, London
    these boots are a bit of a problem lately.
    if you've adjusted the catch i don't know what else to suggest....but don't fret, someone will be along shortly
    [Ex]Admin Duncan's Avatar
    It's more than likely the catch plate (the little bar thing on the boot lip part of the car. They don't need to be out of alignment much for the sensor to not think the boot is shut. Try moving the plate a small amount one way and then the other way if that doesn't work - if you see what I mean.
    Oct 2006
    Midlands
    Thanks for the replies, I have tried moving the catch plate about but to no success....the local independant vauxhall centre has said I need a new latch????
    anyone else come across this problem, sounds simple to rectify but is being a pain!
    just a flying chance.. is the loom plug in there nice and secure??
    Oct 2006
    Midlands
    I think I have found the fault now, I found a loose/break in the wire from the entry to the hatch(grommet) to the lock itself...thanks for the help.
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Can't open boot - 2003 Vectra Sxi Dti 16v (4 Door Saloon)
    By BlackpoolJames in forum Bodywork & Interior
    Last Post: 29th May 2012, 11:43
  3. boot open indicator light is on
    By faizyan6000 in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2011, 15:45
  4. Vectra C 2005 Estate with boot that wont open
    By skip85 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th February 2010, 10:33
  5. Boot Open Sensor/Indicator
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 23:25
