Thread: extrons
    Jul 2011
    UK
    Year : 06
    Cool extrons
    Any one here had or have one these double din headunits there dirt cheap on the bay how do they for in are the snug or stick out a mile also some say about steering wheel controls do they work with it don't want to loose trip computer extra
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    Here is my TD714G fitted in my pre facelift 2002.
    It does 'stick' out by half an inch due to the screen needing to tilt to open etc. On my pre facelift it has half CANBUS meaning it has analogue streering controls and can interface directly with the Xtrons. On Facelift models you have full CANBUS and you will need a converter / interface module. If fitted correctly your seperate display will work as before, but not display and radio or CD information etc. It will be just a trip computer with clock and temp.
    I love mine and its dead easy to install but you will need a booster / amp for the antenna to get the best signal. Oh and you WILL need a cradle fitting kit as Xtrons dont come with them and a face plate adapter that may need to be modified a little.
    Jul 2011
    UK
    Year : 06
    Looks good a seen a td601 2011 model for 174 pound could I not just buy a vectra facial kit as that comes with cage
    Apr 2011
    Somerset
    Quote Originally Posted by marc vectra sri View Post
    You can indeed like these which is who I used;
    http://www.nexxia.co.uk/products.asp...etailed+Search
    But I still had to modify the facia as they are not designed for tilting units. They are for fixed aspect units. It's easy to do and doesn't take long.
    Jul 2011
    UK
    Year : 06
    Yer the one a seen is a fixed unit a think disk go on front not under screen or there is a beat one same as it but that is a fixed unit looks flat and flush
