Thread: removing fuel from a Corsa
    Edinburgh
    Default removing fuel from a Corsa
    I'm quite shocked at how easy it is to drain fuel from a Corsa B.
    My wife has decided to have her corsa B salvaged after the brakes on it failed and gave her quite a fright. They are coming tomorrow to take it away. Unfortunately she had just put £25 diesel in it before it happened.
    I thought about syphoning it out but it wasn't going too well. So i looked underneath the car and found a fuel line with a connector right beside the tank. I disconnected it and out started pouring diesel. Got 4L so far and probably another 15 to go.
    Surely they should make it a bit harder for someone to nick your fuel?
    11 Post(s)
    Quote Originally Posted by Big Knox View Post
    No matter how hard they make it, a cordless drill and bit is no match for the fuel tank. Either that or a screwdriver and hammer.
    Edinburgh
    True although surely drilling into a tank is asking to set yourself on fire? (at least with petrol)
    most petrol tanks are made of plastic now
    11 Post(s)
    The liquid itself doesn't burn. It's the vapour that does.
    Theoretically you could chuck a lighted match into a bucket of petrol and the match would just go out. Getting it past the vapour that's on top of the petrol is the difficult bit.
  1. Removing fuel filter pipes
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 11:51
  2. Removing high pressure fuel pump question
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 16th February 2012, 00:03
  3. Any advice on removing & replacing Fuel Filter ??
    By Cilldara1 in forum Engine & Drivetrain
    Last Post: 2nd July 2007, 07:17
  4. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
