View Poll Results: whats your choice
Voters
5. You may not vote on this poll
  • keep and hope someone knows the answer which is not expensive
    4 80.00%
  • trade it in and fork out more on new car
    1 20.00%
  • try sell private,dust in starter motor from flywheel so can sound bad,engine rattle/smoke on startup
    0 0%
Multiple Choice Poll.
Thread: what would you do
    Regular Member bunsen1's Avatar
    suffolk
    Default what would you do
    hi guys, following on from this original post
    http://www.vectra-c.com/forum/showthread.php?t=133179
    owned the car since april 2010
    flywheel and clutch
    uprated manifold
    4 tyres
    new thermostat
    front brakes
    plus bits and bobs fuel filter oil filter ect
    car has done me for £1500-1700 quid, i know some are wear and tear but hey
    the smoke and engine judder on start up is getting worse, i cant afford to throw more money on the engine if its a big cost for something, even though i still dont know what it is causing it, blue smoke indicates ol yeah?
    what would you do?
    any ideas what it can be? please please please
    tried bg244 recent oil and filter change. de coked today so waiting for that, though after little run and thrash it cleared some early but black smoke!
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    May sound silly, but have you tried getting the dealer to diagnose it?
    suffolk
    no, been off work after acl reconstrucion for quite a while and nearly finished a phased return to work so money has been very tight, go on hols in august and had to borrow a bit to pay for it now, so im trying to scrimp through, if no spanner light shows can they still get a fault code for possible problems, or can they diagnose with no spanner light?
    Engine : 1.9 CDTi
    Or post up in your region and see if anyone has Vaux-Com type software and can read any codes for you.
    suffolk
    worth a try i guess
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Just clutching at straws here but if its getting progressively worse, could this be down to injectors. Don't know too much about dervs but as you've more or less replaced the other major parts, not sure what else it could be
    Porus/cracked Fuel fitler housing maybe???
    Hope some of our more knowledgable folk on here can get you sorted
    Best of luck for a speedy recovery with the ACL (had my PCL, MCL & Post lateral corner reconstructed twice so know what your going through)
    All the best and good luck
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    suffolk
    fuel filter seemed ok when changing, no leaks afterwards
    thanks mate
    north east
    You have done the expensive work but have you looked at some of the basics ?
    Check intercooler pipes for splits, Check intercooler for splits.
    Check / replace vaccume pipes with some silicone pipe off ebay ( about £4 a meter )
    Clean out inlet manifold with carb cleaner. ( £5 a can from halfords 6 squirts and leave to soak for 30 mins)
    Clean intercooler with carb cleaner ( again 6 quirts and leave for 30 mins)
    What colour is the smoke and are you using any oil ?
    suffolk
    can you point me in the direction of the intercooler and pipes and what to look for?
    i have done the vacume pipes with the blue silicone from another post as recommended.
    manifold was only done in june last year roughly
    smoke is blue with tint of whiteness maybe, but mainly blue i beleive,
    dont think im using oil but i will have to check that out
    north east
    The intercooler pipes are the big rubber pipes, One connects from near the oil dip stick to the intercooler, the other from the intercooler to the intake manifold at the back of the engine.
    Check your oil and coolant levels if they are fine its probably oil residue in the intercooler which is normal and common with higher milages but carb cleaner will remove most of the build up.
