Thread: b2966 driver doorknob circuit
    May 2011
    bispham, blackpool
    Default b2966 driver doorknob circuit
    hi all just replaced the cig lighter fuse as it was blown so thought would put it on fault code reader just to see any more hidden codes it came up with b2966 driver doorknob circuit open or high voltage
    ive checked all fuses their fine anyone have any ideas or is it a new doorknob module needed more to the point what is it what i have noticed is if i put the drivers door knob down when im sat in the car none of the other doors lock
    May 2011
    bispham, blackpool
    just found a solution at
    http://www.vectra-c.com/forum/showthread.php?t=54393
    just basically dont worry about it it says a lot of vec c have this code
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    just ignore it.. i have it to
    Mar 2011
    Bulgaria
    I can not ignore any longer. I can not afore buying battery every year.... If anyone find solution like replacing Driver Door Module or any other please let me know....
    More info here
  1. error code B2966
    By CristianTM in forum General Chat
    Last Post: 27th January 2014, 18:10
  2. Replies: 9
    Last Post: 15th October 2010, 17:57
  3. Advanced driver courses.(Class A driver)
    By Craig1985 in forum General Chat
    Last Post: 19th August 2008, 10:48
b2966 cristiantm
b2966 Opel
driver door knob circuit open or high voltage
b2966
