Results 1 to 3 of 3
Thread: CIM Numbers
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default CIM Numbers
    Hey all,
    Someone on here suggested that when buying a CIM unit off Ebay or anywhere you need to match the numbers up from your old one. Here's a pic of mine when changing my steering wheel over, am I right in thinking it's the "XU" number that needs to match? On Ebay someone has suggested it's this number, can someone confirm?
    Full Member
    Bristol
    Hello mate . yes it imperative you use the same one. The only other one that will fit is an XR witch now repalces XU at VX Dealer. If you try and fit any other you will run in to all sorts of problems. Check to see if its been depaired before removal as you can't use one that is not.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by sb1uk View Post
    Excellant, thanks for the info! Now just got to find one LOL.
  1. anyone know what these numbers mean
    By bangty 1 in forum The 'Off Topic' room
    Last Post: 16th December 2010, 22:12
  2. useful numbers
    By chrisgettings in forum General Chat
    Last Post: 9th October 2008, 14:15
  3. numbers numbers numbers
    Last Post: 17th January 2008, 20:51
  4. Numbers
    By Brocks in forum General Chat
    Last Post: 14th June 2007, 12:59
