Thread: 10K De-coke query
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Default 10K De-coke query
    I am about to clean the boost sensor, EGR valve and air intake. Probably a stupid question but is this stuff ok to do all of this http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Or do I need something different for the boost sensor?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Egr 3 i find is good for giving the whole system a clean out , usefull for doing the parts that are not so easily removed , like the lower inlet manifold
    But if i was going to try and do this properly then i would also remove the boost sensor ,egr , and upper inlet manifold and give these a seperate clean out with carb cleaner , The danger with using egr 3 is that can dislodge particles in the manifold which can find there way onto the egr and boost sensor
    Jun 2011
    Elland
    Quote Originally Posted by bobssignum View Post
    Not to mention shove it all into the DPF, if you have one.
    north east
    remove the boost sensor first clean that on its own in some carb cleaner, then spray 6 shots ( 3 either side of the butterfly for evenness ) 10 k is just very expesive carb cleaner which is about £5 a can.
  1. de-coke
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 21st February 2013, 17:06
  2. De-coke..
    By nikroc in forum General Motoring Chat
    Last Post: 5th May 2012, 09:16
  3. EML on after de-coke?
    By paul_sri150 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 08:10
