Thread: Will front fog light fail MOT
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    Question Will front fog light fail MOT
    Hey all,
    My right front fog light is very heavily condensated and it will not clear. I've had the light on for two hours and left it parked in the sun etc.
    It's been like it since I've had the car but MOT is due in a month, I'm unsure if it will fail or not. There are no chips or cracks that I can see in the lens so just think a seal has gone or the drain is blocked.
    Any ideas on if it will fail please?
    VF
    Front fog lights are not a fail...
    Regular Member megsdad's Avatar
    May 2011
    Northwich, Cheshire..
    10 Post(s)
    Vehicle : SRi Estate Nav
    Trim : Boring cloth
    Engine : CDTi 150
    At the moment the operation of front fog lights are not part of the mot test, however they will be classed as dangerous and fail the test if they have cracked lenses.. Good luck.
    staffordshire
    My fog light has a cracked lense and is misted up with condensation but still passed the MOT at a vauxhall dealer on Saturday !?
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    my left dosent work and it passed on saturday i even pointed it out to the examineer he said it is only the back we check
    take the cover of for an hour or 2 and then put a silica sachet in the back of the light and put the cover back on should sort it out
    Feb 2011
    Selby
    Front fog light operation as said above isn't part of the MOT.
    A cracked lens also isn't a fail, unless the crack is such that you have broken glass with edges. It's part of the 'anything sharp likely to injure someone' bit of the test.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    had same problem,removed plastic back cover and took the bulb out left it for an hour sorted,and is still ok dont know how it got in there to start with though,had plenty of the wet stuff since and fingers crossed still clear.
    Engine : 1.9 CDTi
    One of mine kept misting up.
    Just took the cover off and its been fine since.
    Ashington, Northumberland
    Quote Originally Posted by megsdad View Post
    .... however they will be classed as dangerous and fail the test if they have cracked lenses.. Good luck.
    No they won't. Advise only
    Quote Originally Posted by rich r View Post
    This also isn't a fail, just an advisory. That part of the test is judged by forming the opinion if somebody walked past it and brushed up against it, would it injure/hurt them. The answer to that one in this instance is no, so it's not a fail. If it was a headlight glass, then it would be a fail as someone could catch their hand against it or their clothing because the headlight is exposed enough for that possibility, a fog light isn't. well not a Vectra one anyway.
    Apr 2011
    Somerset
    Thanks everyone for your input. I'll have the back off this weekend and 'dry' it out and then sail through my MOT
    VF
  1. Replies: 12
    Last Post: 14th March 2012, 13:25
  2. Front Fog Light
    By kevrod79 in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2011, 10:17
  3. front fog light
    By vectra craig in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2009, 22:46
  4. front fog light mod
    By tonka2 in forum Styling
    Last Post: 8th June 2009, 18:28
