Thread: 150 probs
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default 150 probs
    Im getting a slight loss of power when in third gear sometimes 2nd, only at low revs.
    the engine seems to hesitate for a second, and then the power builds up ( almost like you have chosen the wrong gear sort of feeling) ?
    i had the inlet manifold done about 3 months ago, and i have only 42000 on a 56
    any ideas
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    EGR??
    Also check around the vac pipes, although any splits would usually throw a warning light on.
    hth
    Jun 2011
    Liverpool
    give the boost sensor a clean also m8.
    Feb 2006
    north east
    thanks , i know my AA warrenty will not cover th EGR
    Feb 2006
    north east
    Quote Originally Posted by c4rlos View Post
    should i just use something like 10 k boost?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by The Gas Man View Post
    The boost sensor just unscrews from the inlet. Clean it in carb cleaner.
    No harm in using 10k boost, although I chucked a whole can of carb cleaner through my missus' CDTi 150 the other day with fantastic results, as seen here with a few other bits... http://www.vectra-c.com/forum/showthread.php?t=142503
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    EGR valve or vacuum hose splits. If the car has only had the manifold replaced 3 months ago, and judging by the age and mileage you state you don't do alot of miles, a 10K decoke wouldn't me much benefit tbh.
    EGR valve is probably the culprit anyway.
    Feb 2006
    north east
    thanks mate , my mission for the morn is to find were the boost sensor is, also seek out any splits, also E.G.R is this a DIY job as i am a heating engineer , so fairly mechanically minded
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    http://www.vectra-c.com/forum/showthread.php?t=88845
    Feb 2006
    north east
    been on here since 2006 with my first vec 1.8 , great people great help thanks
  1. big probs :(
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 18:48
  2. more probs
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 05:41
  3. hid kit probs
    Last Post: 15th May 2010, 19:23
  4. big probs
    By dextrovix in forum Engine & Drivetrain
    Last Post: 30th November 2006, 08:10
