Thread: Rear light bulbs
    Regular Member shillbag's Avatar
    Apr 2006
    Leicester
    Default Rear light bulbs
    can anyone tell me about vectra lights please ?
    i have a signum so i am not much help. my uncle has a vectra and the bulb warning light is showing on the dash, in the rear light, is the two bulbs or one as it looks as though that could be the case. all other lights are working ok, brakes reversing and fog lights are all ok, so are all other lights on the car.
    hope someone acn help so he stops hassling me
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    IIRC there should be four 21 watt bulbs in each rear light cluster and I think I am safe in saying that he could use the one from the fog light that doesn't operate as a spare. The car is designed to use the side light if the brake light fails and vice versaso a giveaway of a dead brake/side light bulb is one higher up than the other.
    I think this is what you were asking?
    Dave
    Feb 2006
    Dorset
    The car will warn you a bulb has gone , but will utilise the other sidelight bulb as thebrake or then the foglight , hence why there is still 2 foglight bulbs in the facelift but only one is used as fog . must clean up the connections on mine as when i got it back it kept telling me the reversing lights were not working when they are , bluddy can bus.....
    Jul 2006
    Cheshire
    Are you sure about this Dennis? ... other threads have said that wiring does not exist to the foglight bulb that is not used ... some members have run a wire to this bulb to make the fog work.
    Dave
    Feb 2006
    Dorset
    i think the wiring is there but that particular light is disabled when it leaves the fectory , i will have a look when i get mine back (hopefully with the right bumper and fully sorted out !
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by ukanalyst
    Dave
    Opened mine up today and ran a wire across. I need to get the silver bit to go into the connector, have one some somewhere in that damn shed, bet it's the last box, anyway, shoved the wire in as a temp measure and hey presto we have light. I just need to make it permenant
    Jul 2006
    Cheshire
    Quote Originally Posted by willc01
    I guess that confirms it then ... so you could use this bulb as a spare in that case.
    Dave
    Apr 2006
    Leicester
    thanks guys for the useful info, i will pass it on
  1. Fog Light bulbs
    By DeeBe in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2011, 19:30
  2. Fog light Bulbs
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2011, 16:48
  3. H11 Fog light bulbs Help Please
    By Tomb in forum Styling
    Last Post: 25th January 2011, 04:57
  4. Rear tail light bulbs?
    By Kieran1981 in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2009, 05:43
  5. Rear reg plate light bulbs- Size needed?
    By Polish08 in forum Styling
    Last Post: 3rd July 2009, 18:07
