Results 1 to 10 of 15
Thread: Vectra C 1.8 SRI loseing water
    May 2011
    STAFFS, UK
    Default Vectra C 1.8 SRI loseing water
    Hi guys i ahve a problem infact a few but the major 1 is my car is looseing water, i would say every few weeks it looses about 4 cm from the filler. I also seem to have bad mpg (average 25mpg on a trip still poor maybe 27mpg), car starts up first time, very quite engine, seems to hesitate at times and performance is up and down tbh as sometimes i put my foot down and car does nothing and sometimes it wants to go but in general id say poor, temp guage sometimes bit dodgy but works most of the time, fan kicks in at 92c,its been like this since i had it a few months ago ive just not had time to look into it.
    ive recently changed the spark plugs and cambelt done few thousand miles ago (currently at 115k).
    also have a clutch problem that ive just left to see what happens and it seems if i drive the car bit heavy the next day i carnt engage the clutch to put in gear, the clutch feels almost gone, after 15 mins of driving clutch starts to feel normal and i can get into gears more smoothly.
    i get some kind of noise on pull off (clutch/gearbox) which i think is because of this clutch problem.if i drive steady clutch operates fine althoigh to me feels like its sticking.
    clutch bite point is far down.
    any help would be most gratefull
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    1st port i would say the stats ****ed, next on the clutch sounds like its on its last legs too, 100k is pretty good for a clutch imo
    May 2011
    STAFFS, UK
    so u recommend i change the thermostat?
    o dear hope its not my clutch as i sold my 307 hdi because it kept giving me problems and had to fork out £500 for it for flywheel and clutch before i sold. Grrrr. .
    Do you think a garage would no if its a nacker?
    Regular Member mat osborn's Avatar
    Jan 2008
    leicester
    check waterpump mine was exactly same with waterloss.when i did it there was very slight rust stains on tell tale hole only found it as put cambelt kit on and thought might as well change pump.
    scotland
    if there are no visable leaks in the system I would (and hate to say) it could be your head gasket ,
    May 2011
    STAFFS, UK
    Quote Originally Posted by gsxrster View Post
    Ya reckon? even if car idles fine?, im clueless tbh
    scotland
    well the water must be going somewhere , get the sniff test done in youe expansion tank
    uk
    If the clutch comes up after running it may be the brake lining are low, sounds silly but to operate, the brakes have to move further because they work through the same system or the air pump as a small leak which is allowing the pressure to drop while not in use
    May 2011
    STAFFS, UK
    Quote Originally Posted by kel123 View Post
    Strange that as I have problems with brakes they squeal all the time, I've even had them copper greased but still squeal and not very good neither, I'm asuming u do mean the brakes.
    May 2011
    STAFFS, UK
    Sniff test?
  1. vectra 2.2 dti water in oil
    By gixerjd in forum Engine & Drivetrain
    Last Post: 20th February 2013, 21:46
  2. Vectra C water in footwell
    By PittStop in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2012, 16:24
  3. Losing Water Vectra C 1.8 vvti
    By demoni in forum Engine & Drivetrain
    Last Post: 17th January 2011, 10:00
  4. Hi there - Water getting in my vectra boot
    By jacko52 in forum Bodywork & Interior
    Last Post: 6th August 2008, 12:03
  5. Vectra C Doors water retention
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2007, 18:22
