Thread: glow plug problem or relay??
    Jun 2011
    manchester uk
    Default glow plug problem or relay??
    Hi all,
    I am a new member and have an issue with the car and spanner light showing on the dash for the first mile of driving, it normally goes out, sometimes it can come on during a drive and tends to stay on longer after stopping and then starting again.
    after an opcom diagnosis check i get the following
    Fault codes
    P0380 - Glow Device General Error
    (08) - Not present
    P0650 - Malfunction Indicator (MI) Control Circuit Open
    (04) - Not present
    i have then gone on to do a couple of output tests, here are the results
    Glow time telltale test
    when running i get a Glow plug light showing on dash
    Glow time relay test
    Battery voltage 12.3
    Glow time relay inactive 12v
    Diagnosis glow time relay inactive
    i then pressed run test and got the following
    Battery voltage 13.4
    Glowtime relay active 0v
    any ideas anyone befor i go out and buy a relay and or glowplugs??? anyone prepared to run the two tests above and see what you get or can inerpret the results??
    Simon
    West
    do you drive an estate & or auto?
    Jun 2011
    manchester uk
    Default vectra
    no mine is a 1.9 cdti sri hatch 150ps 2005
    Full Member
    Bristol
    Relays rarley go probably glow plug. I would change them all.
    Engine : 1.9 CDTi
    Do a resistance test on the glow plugs.
    Take the plug off the top and put a meter between the tip and a good earth.
    Should be about or less than 3 Ohms (I think)
    Jun 2011
    Liverpool
    read a similar post and it said around 30 ohms m8.
    measured 1 and 2 on mine the other day , one was 1460 ohms and no 2 didnt even register !! Having trouble getting them out though.
    Full Member
    Bristol
    Another good test is if they glow red at the tip they are ok if they glow red in the middle or do not go red all they destined for the bin. Nothing better than good old diagnostics.
    Jun 2011
    manchester uk
    Default fixed
    i replaced the glow plugs and the glow plug code went but the P0650 code persisted, i finally traced it to
    (04) - Present
    this turned out to be the instrument cluster, remove both trim strips one above the radio and one above the headlight switch, lower the steering wheel and unclip the instrument cluster surround, there are then two torx screws holding the instrument cluster in, i removed the connector at the back of the cluster before cleaning both male and female connectors with wd40/cloth, re-assembled and the light has not come on since.
    hope the above helps someone.
    Simon.
    Engine : 1.9 CDTi
    Thanks for the update
  1. glow plug relay
    By iwtand in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 14:25
  2. For Sale: Switches,Glow plug relay
    By bigmac in forum Parts for sale
    Last Post: 14th June 2011, 20:00
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
vectra 1.9 cdti p0650
diagnosis glow time relay
glow relay active 0v is this normal
vauxhall vectra glow plug relay
vauxhall vectra 1.9 diesel glowplug relay
vauxhall vectra sri cdti 150 glow plug relay location
