Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: 2 sighn in accounts on pc
    Regular Member the fisherman's Avatar
    manchester
    Default 2 sighn in accounts on pc
    when i start pc up i have 2 options to which account i can sighn on to.how do i get rid of one of them to keep one sighn in account.there both on the same drive c drive
    Mileage : 55000
    How do you mean, are they accounts to assess the PC so to speak, like the choice of which profile you use.
    manchester
    yes thats it bud
    Mileage : 55000
    What system are you using. There should be somewhere, where you can "add a profile". I would inagine that you can delete "a profile" from there too. On our old PC we had Three profiles. I forget how we set them up, as our new PC is windows 7.
    But I dare say someone will have the information you are looking for.
    Just had a thought. Look in control panel, it might show "users" it may have both the profiles you are looking for.
    Mileage : 55000
    Just had a look on mine.In control panel there is the "page" user accounts and family safety. from there you can add or remove user accounts.
    manchester
    im useing windows xp
    manchester
    no it does not let me delete one of the accounts from there,but ive done it before from a different spot
    May 2011
    bispham, blackpool
    Quote Originally Posted by the fisherman View Post
    you can delete the account you are not logged on to or when you log on does it say guest acc if it says guest acc all you need to do in user accs in control panel go to change acc and turn guest acc off
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Control Panel/User Accounts...What Are The Accounts Called ?
    Should Be Able To Delete From There
    Full Member spennny's Avatar
    Blantyre
    If am reading it right I had the same issue a while back
    Right click my computer
    Click Properties
    Click Advanced tab
    Under startup and recovery click settings
    (Theres a little dropdown box which will have the 2 titles win xp etc.)
    Click Edit (this is win.ini) and delete the 2nd title one this will take it away at startup and appear normal
  1. looking for a sighn maker
    By the fisherman in forum General Chat
    Last Post: 6th March 2011, 19:32
