Thread: Front Camber Adjustment
    Oct 2009
    Redditch
    Default Front Camber Adjustment
    Hi,
    Need to adjust the front camber on my Signum, first is it possible, as at the moment just straight thru bolts fitted.
    Engine : 1.9 CDTi
    There will be about a degree of adjustment in the holes.
    How far out is yours?
    Oct 2009
    Redditch
    The n/s -0.57 and o/s -2.54
    West
    Oct 2009
    Redditch
    Have you got these fitted?
    West
    I bought a set when buying the full shocks (reflex) & springs (gts) from Monroe, although when everything was fitted, there was no need to use them as there was no adverse camber...
    is your motor lowered or are you running standard equipment?
    Oct 2009
    Redditch
    No running standard spec. Had new monroe reflex fitted also, as well as springs. The link you sent, (MC117) they are for Toyota Estima / Previa. Checking on the same site Signum 2.2 dti should be MC112, but only from chassis no. 51000001, mine is a 484*****.
    Anybody know what the difference is or if they would fit?.
    West
    The link was just a generic link to be honest, as you're running standard springs, there should be no need for these bolts... who ever fit the kit has not set it up correctly
    Oct 2009
    Redditch
    Looks like a trip back to the fitters
  1. Camber adjustment?
    By Neil07D in forum Handling & Braking
    Last Post: 22nd January 2012, 11:20
  2. Front camber adjustment?
    By Tayla in forum Handling & Braking
    Last Post: 13th November 2010, 14:01
  3. Front camber adjustment?
    Last Post: 11th November 2010, 17:56
  4. Rear Camber Adjustment
    By spoons in forum Handling & Braking
    Last Post: 10th November 2010, 22:00
  5. camber adjustment
    By hagga in forum Handling & Braking
    Last Post: 12th November 2007, 15:45
vectra c front camber
