Results 1 to 10 of 11
Thread: Insignia 2.0 CDTi (160ps) Power Loss
    Jan 2010
    Motherwell
    Default Insignia 2.0 CDTi (160ps) Power Loss
    Having problems with my Insigia 2.0 CDTi SRi (160ps) which has only done 11k miles: after driving for about +30 miles motorway driving and then returning to urban driving the car will suffer major power loss, when idling the engine "knocks" (rattles) badly and the rev counter bounces erratically between about 700-1000RPM (no DPF or any other errors flagged in the driver display panel). If I floor the accelator when still in neutral the car fails to reach 3000 rpm !!! Having to turn off ignition and switch back on in order to clear. Been like this since car was about 6 wks old - now had it 18 months since new and booked back into to dealership for the 4th time. Previous 3 times no fault found but they did try to spin me a yarn about 1st time round about recall for the BCM (Body Control Module) being a remedy !! If no fault found this time they're also going to charge me £72 !! Anyone else experienced these symptoms??
    Edinburgh
    take it to a different stealer tbh
    Chester
    BCM recall was to prevent the battery going flat.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    I would go to a different dealer and contact Vauxhall customer service, your dealer sounds rubbish
    Glasgow
    As above contact vauxhall customer care and explain it all to them be nice and they will do everything possible to help you. Also note down the case number they give you and when you take the car in to the dealer give them the case number also so that they know you mean business.
    Sodding Typical on Sea
    Yip, as above, go to a different dealership and DO call Vauxhall cust service this has been a long standing issue and one they have failed on several occasions to resolve.
    Jun 2011
    Elland
    See if you can demonstrate the fault to them. Just because they can't find or diagnose it doens't mean you should be charged £72 for their incompetence. Also try a different dealer as suggested.
    Jan 2010
    Motherwell
    Thanks for the feedback guys but just to let you know the problem with my 2.0 CDTi 160 SRi has still not been remedied and if anything is getting worse. Different dealer still unable to duplicate the fault and I've now generated my own diary of occurrances to take it back up with the dealer. Also contacted VX HQ and have a case number raised against the claim for tracking purposes. I did receive one piece of information thru a friend of a friend of a VX mechanic who said it maybe possible that wiring harness is rubbing against injectors and causing the engine to drop to 3 cylinders - planning to share this info with the dealer and get the car booked in yet again!
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Trading standards m8, your car has a problem at low mileage and tbh Vauxhall should be covering the cost. Simple. Don't hand over a penny and if you do keep the reciept, phone trading standards s oin the end you can reclaim the money which you shouldn't be paying.
    Insignia VX-Line Nav CDTI 170.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Car's still under warranty. You should not be charged a penny for whatever a dealer has to do to put it right.
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. Loss Of Power On 3.0 cdti sri - please help
    By L.Hamilton in forum Engine & Drivetrain
    Last Post: 14th June 2011, 18:00
  3. Power Loss on 3.0 V6 CDTI
    By V6Andy in forum Engine & Drivetrain
    Last Post: 1st March 2010, 23:59
  4. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
loss of power problem in vauxhall insignia
vauxhall insignia loss of power
vauxhall insignha 2 Ltr cdti problem with loss power what to do
vauxhall insignia no power
https:www.vectra-c.comforumshowthread.php142582-Insignia-2-0-CDTi-(160ps)-Power-Loss
vauxhall insignia loss of power when accelerating
insignia no power
insignia loses powerlack of power on 2012 insignia 2.0 tdivauxhall insignia 2.0 cdti loss of powervauxhall insignia diesel loss of powerVauxhall Insignia diesel car dropping powervauxhall insignia losing powerinsignia cdti down on powerinsignia diesel loss of powerVauxhall insignia 09 plate loss of turbo or lack of poweerloss of power on vauxhall insigniavauxhall insignia down on powerinsignia diesel loss of power how to fixvauxhall insignia no accelerationvauxhall insignia 2.0 cdti elite no power insignia sri cdti loss of powerwhy has my insignia lost powervauxhall insignia intermittent power loss
