Results 1 to 10 of 13
Thread: Vectra CDTI SRI (120)
    Regular Member meridian9's Avatar
    Jul 2010
    Blackpool
    Vehicle : Vauxhall Insignia
    Trim : SRI Nav
    Engine : CDTI 160
    Default Vectra CDTI SRI (120)
    Hiya,
    Going to have a look at a car tomorrow
    Its a 05 plate 1.9 CDTi SRi, with 105,000 miles. Is there anything I should be particularly cautious about? If the clutch/DMF hasn't been done, should I bother looking?
    Body work wise, it seems ok in the photos.
    Thanks for any help!
    Dave
    RINGWOOD
    Quote Originally Posted by meridian9 View Post
    Hiya,
    Dave
    well you"ve got no swirlflaps on 120 model so thats a bonus.yep i think the clutch is the one to listen for - see what history / bills owner has.make sure car still drives well and revs nicely.120 still has egr valve and when clogged can make it a dog to drive. also this model is great with a tuning box on - had mine for 30k and with box on completely transformed car in terms of performance and mpg.
    Jul 2010
    Blackpool
    Trim : SRI Nav
    Engine : CDTI 160
    Quote Originally Posted by pompeydave View Post
    no swirl flaps?! excellent! I was told that the 120's still had them lol
    RINGWOOD
    no not on the 120 - no inlet manifold problems to think about.
    On a Sabbatical mickeystitch's Avatar
    Mar 2007
    peacehaven
    what tuning box do you have
    RINGWOOD
    Quote Originally Posted by mickeystitch View Post
    i had a dtuk early green box on - big difference. but my egr went a couple of months later....coinsidence ???? changed that and went on for a further 25k miles...no problems.
    Mar 2007
    peacehaven
    cheers fella, might have to give one a try
    RINGWOOD
    well worth it , its amazing how much extra performance is available with box on.also my mpg went up slightly if driven normally !!! but the temptation to put your foot down a bit is always there but equally knowing you have it on tap if required.
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Not strictly true
    Apparently there were a few vectras that came out with a detuned 150bhp engine but for the life of me can't remember where I read that. The only difference was that It was mostly software that brought the power down to the 120 mark so with a remap it would be back up to the 150 or even 180/190bhp mark.
    Few things I would say to look out for, would be the occasional twang from the front springs, when steering left or right. Try turning to full lock in both directions, could indicate a broken spring which these are renowned for
    Another thing that I have noticed more and more just recently is brake creep (when pressing the brake peddle it will depress to the floor after a few seconds. Which could indicate corroded pipes/servo or rubber grommets in master cylinder allowing air in. Not hugely common but starting to notice a few threads about it on here
    Other than the Clutch/DMF or EGR issues they are quite a reliable car
    Hope it helps
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    lincolnshire
    other than the DMf i'd say next is cambelt/waterpump change , this is a must as they can go without warning and the waterpump does not always get done when it should , so check service records , cold starting can be a pain too , so make sure it fires straight up when ice cold
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Vectra 1.9 CDTI Sri Versus 3.0 CDTI V6 Sri
    By collateral in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 20:18
  3. FS - Vectra SRI CDTI 150
    By rscosworth in forum Cars for sale
    Last Post: 16th July 2006, 22:11
