Likes Likes:  1
Results 1 to 10 of 23
Thread: Wiper linkage cable ties fix with photos
    Durham
    Default Wiper linkage cable ties fix with photos
    OK, yesterday my passenger side wiper stopped working. I remembered the wife's car having the same problem fixed under warranty, but mine is a 55 plate and hence well out of it.
    Having looked around the forums I've seen a few mentions of fixing the problem with cable ties / tie wraps but couldn't find any photos. So I thought I'd try to take some pics while I had a go at fixing the linkage.
    Attachment 44591
    On opening the bonnet I could just see through the plastic grill covering the linkage that one of the arms had come off.
    Attachment 44592
    Pull the rubber sealing strip off up to about half way across the engine bay. Lift up the corner of the plastic cover over the linkage (you'll have to peel back the sticky foam block at the outside end to do this)
    Attachment 44594
    Then wedge the cover up with something. Luckily I had a block of scrap wood just the right size.
    Attachment 44593
    Now I could see the bottom arm hanging off. Low and behold, pre facelift brown ball and socket joints.
    Attachment 44595
    Sprayed some grease into the socket for good measure.
    Attachment 44602
    Attachment 44603
    I'd read in another post that there's not much room in there, so I used a special tool (wire coat hanger modified) to lift up the lower arm.
    Attachment 44597
    Attachment 44596
    Attachment 44598
    A bit of finger pressure and it clicked back into position. Be careful of the metal edge where the rubber sealing strip was, it's sharp enough to cut.
    Attachment 44599
    I had some 200mm x 2.5mm wire ties in the garage, so I bent them a bit to get them over the top of the linkage and come back towards me underneath. The special tool was handy again to coax the ends up to where I could grab them.
    Attachment 44600
    I put two cable ties on because this had been mentioned in other posts. I suppose you might get away with one wider one, but it might be more difficult to fit if it isn't very flexible.
    I tightened the cables up, but nut really tight. They need to hold the bottom arm on, but also need to be slightly slack to allow for movement of the link arms.
    If you start the wipers at this point you'll be able to see the amount of movement there is. I was a bit worried that the wiper arms might catch on the bonnet when it was raised, but they don't.
    Attachment 44601
    I just tightened the ties to where they looked as if they weren't under any strain, but they were holding the joint together, then clipped the excess off.
    Put the cover and foam block back, refit the sealing strip, and job done. I think it took half an hour including time to take the pics.
    I understand there are new link arms available on eBay, but being tight I thought I'd try this quick fix first and see how long it lasts.
    Hope this is helpful for someone.
    Mar 2011
    n. ireland
    good job rich good photo,s as well always helpful
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    cracking work going to look at mine later
    West
    That's exactly what i did on my old preface, the temp fix lasted the whole 2 years while i owned the motor & is probably still holding the linkage in place now 4 years down the line
    Engine : 1.9 CDTi
    Is it just the arm sockets that wear as you can get new arms for £26: http://cgi.ebay.co.uk/SIGNUM-VECTRA-...item5ae1867cb6
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    i do like homemade repairs, cable ties are great
    Sep 2011
    Kent
    my passenger side wiper, judders a bit and doesnt always park back fully quite often a good few inches up the windscreen. Is my wiper linkage thing on the way out and would the cable ties help ?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    A top tip is to add another cable tie on the upper arm ONLY and pull quite tight just to the right of the 2 tie wraps (as shown in the last picture, about where the second crimp is located). this stops the tie wraps slipping along the arm and as there is more relative movement the further you go along the arm can snap the tie wraps.
    I did this temporary repair to mine about 4 years ago, and it's still working as a temporary repair.
    Regular Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Ive almost done the samething but i used an old football boot lace!
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    I had this problem a few years ago & solved it in a similar way by putting a cable tie each on the arms & linking them with a 3rd tie, so its a bit like a chain, giving a bit more flexibility. Had no problems since.
  1. Wiper linkage
    By Mr Owens in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2012, 09:16
  2. cable ties
    By marc vectra sri in forum General Chat
    Last Post: 10th November 2011, 20:08
  3. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  4. Wiper linkage
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2010, 13:06
  5. wiper linkage
    By IBarfoot in forum Bodywork & Interior
    Last Post: 28th March 2007, 10:03
vectra c wiper linkage
vectra c wiper linkage fix
how to repair wiper linkage with plastic ties
vauxhall signum wiper linkage
vectra c wiper linkage arms
Astra h linkage cable tie
vectra c linkage wiper
windscreen linkage vectra c
fix linkage wiper with cable ties
astra wiper zip tie
vectra c how to fix wipers mechanism
vectra c 3.0 wipers works only on second gear
vectra cdti wiper
Fix chain with cable tie
vectra c wiper linkage zip
fixing wiper with zip.ties
