Results 1 to 10 of 15
Thread: Guide for fitting washer sensor?
    Engine : 1.9 CDTi
    Default Guide for fitting washer sensor?
    Is there a guide for fitting the washer level sensor?
    Part numbers and if you remove the arch liner to drill the hole or take the bumper off and remove the bottle?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    not seen a guide.. but i took out the bottle.. and used a 21 mm drill (didnt have any bigger) then use a dremmel to make it large enough for the sensor and grommit just to push in..
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Quote Originally Posted by kenp View Post
    I second that, you might have to clear out any
    plastic from cutting.
    Engine : 1.9 CDTi
    Just looked it up and the 2 part numbers (Incase anyone else needs to know) are:
    Sensor: 90346055
    Grommet: 90276310
    How easy is it to remove the washer bottle?
    Oct 2010
    Walkden, Manchester
    Quite easy, i remove the bumper, then theres 3 10mm bolts, 2 on the plate behind the wheel arch cover, and 1 behind the bumper just behind the horn.
    I think there is a pic on the washer bottle how2
    http://www.vectra-c.com/forum/showthread.php?t=87195
    Engine : 2.2 Direct
    And you can see here where i put mine (and where it should be).. sorry for the crap picture... but you should be abel to locate it.
    Engine : 1.9 CDTi
    Ok cool,
    Not a 5 min job so will give myself plenty of time.
    Oct 2010
    Walkden, Manchester
    I changed my washer bottle for the bigger one this morning, took about 45mins.
    Aug 2010
    Stoke on Trent
    I have a bottle from a vec c with pump & sensor if thats any use to you Lee...
    Engine : 1.9 CDTi
    Its for another member.
    He has the sensor (Just need to get the grommet) and we will be fitting it (And drill the hole) and enabling the check control
    Thanks for the offer though.
  1. guide on fitting springs?
    By byers in forum Handling & Braking
    Last Post: 21st April 2012, 08:52
  2. guide on fitting springs?
    Last Post: 20th April 2012, 19:39
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  4. Washer sensor...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2010, 15:49
  5. CDTi 150 Caterman fitting guide?!
    By RobW in forum Diesel Engine related
    Last Post: 14th October 2007, 11:36
