Thread: Buying IPF/EDS tool?
    Engine : 1.9 CDTi
    Default Buying IPF/EDS tool?
    Is it possible to buy direct and get it cheaper than through Regal Auto Sport.?
    If you can whats the link?
    Slough
    90 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    http://www.eds-motorsport.de/shop/de...7a4a71486bd611
    Lee this is where Nutron got his from ,cheaper than Regal . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Engine : 1.9 CDTi
    Ah thanks,.
    Any idea how long it took to arrive and how he paid for it?
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Cost about £475 and took two days to arrive.
    Engine : 1.9 CDTi
    Quite a saving then.
    Do you have many maps you can choose from?
    Just wondering if its worth going for it rather than just a remap.
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Initially no, I only had two maps to chose from. I hassled them for about three months though and got a custom map for the hybrid turbo which they hoped would give 230bhp (not tested on the rollers yet).
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Quote Originally Posted by nutron View Post
    Have you used the EDS-IPF unit much? I have used it 3 times, 1st time ok, on 2 further occasions it wiped ECU and dropped me right in the ****, Had to send ECU to Regal on both occasions to have it re-flashed....I daren't use it now....furtunatly I had it last set at 190PS, tried the 200PS and it smoked more for no noticeable gain, bit peaky if anything.
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    You need to leave it until it stops flashing, it takes about 25 minutes on mine. If you lock the ECU up because you stop the process, it has an automatic recovery function. Regal can not do anything with the ECU that you can't with the IPF.
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    I even had a recovery file sent from Germany, seriously it wiped my ECU and I could do nothing. I do wonder if my slow broadband has any effect on things. I carried out instructions maticulasly and leave things longer than necessary to be sure but to no avail. I do find the plug connector to the car a bit vague, so I remove gater trim so I can be sure I get the plug connected fully a due to being a tight fit. When I did it the 1st time it bent the bracket holding the plug as there is just no feeling with the connecting lead
  1. inner tie rod tool
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2012, 14:17
  2. What a tool.
    Last Post: 22nd September 2010, 11:56
  3. Tool help
    By vectra-probs in forum Engine & Drivetrain
    Last Post: 14th July 2010, 09:03
  4. what tool
    By magpie27 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 13:19
