Hi guys new here been reading some posts and thought might aswell join and get these guys opinions.
I had started to notice some White smoke on startup over the last few weeks was nothing major then one day sitting at traffic lights I get this violent juddering. The lights changed and car seemed to be fine after that. Next morning went out to go to work car was really hard to turn over but did with White smoke and the car doing this violent judder again after bout a minute car drove fine. Then started with a slight judder the rest off the day.day 2 the car really struggled to start but started this time with the same symptoms as the day before and White smoke coming from under the bonnet driver side cleared up after a minute again. Decided I would service the car after work. Put in forte engine cleaner let it tick over for 40 mins turned car off. Then it's never started again.
So put it into a vauxhall specialist there was no codes showing on the comp. They then said the woodroof key was worn and had allowed the timing to slip 4 teeth and the gear had to be changed I said go ahead the next day I got a call saying there was a woodroof on the crank and needed to replace that to get the timing spot on so next day speaks to the mechanic and he says all the timing is sorted but the car still doesn't start. He said it's a bank holiday and will look at it on Tuesday again but didn't know why it hadn't started. Anybody else have this problem?
