Thread: Suspension / Steering
    Oct 2009
    Redditch
    Default Suspension / Steering
    Hi,
    Having a bit of a problem with my 53 Signum 2.2 dti. Over the last few months have been having some issues, car some times feels like a shopping trolley when the road surface is uneven. Have had the following replaced / done.
    Rear
    Shocks
    Springs
    Upper Control arm
    Front
    Shocks
    Springs
    Strut bearing
    Top mount
    ARB
    Drop links and both outer tie bars where replaced last year (approx 30K)
    Also had a couple of 4 wheel geometery checks (Hunter), the last one when I had the front shocks replaced showed that the front camber was out -.57 N/S and -2.57 O/S. There appears to be no means of adjustment on the front struts, (vin begins 484********).
    Also steering wheel is no down slightly on the left.
    Any one got any ideas what I need to fix /replace.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Maybe a bit obvious, but how old are the tyres, and have you had all the wheels balanced?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You make no mention of the track rod ends and inner track rods, have these been checked?
    Oct 2009
    Redditch
    Forgot to add have had 2 new tyres on the back also and the rears put on the front. Also all for wheels rebalanced.
    West
    As John says, have the track rod checked
    Oct 2009
    Redditch
    Outer tie bars (track rod ends) replaced last year.
    Oct 2009
    Redditch
    Cheers for the suggestion. OK, off to arrange to get inner ones checked. Is this someting I can do with the car on the ground?
    Also do yo know if there is a way of having the front camber adjusted.?
    Aug 2010
    Derbyshire
    I hated driving my Signum, it was all over the place (tramlining) and pulled to the left slightly.
    I remembered my last car, an Omega had similar symptoms, changed the front tyres problem solved.
    So I bit the bullet and ditched the front Eagle tyres and had some new one's fitted.
    Also had the tracking done. The local garage took an age to get my tracking spot on.
    Everything is fine now like driving a different car, I even love driving it again.
    Mick
  1. Knocking in suspension / steering.
    By lh_4827 in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2013, 21:48
  2. suspension/steering part's limited life ???
    By ditchp in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:28
  3. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  4. Suspension & Steering Noises
    By phil79 in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2009, 00:29
  5. suspension or steering problem?
    By xaviroller in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2008, 11:27
