Results 1 to 10 of 11
Thread: Auto wipers/rain sensor not working
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default Auto wipers/rain sensor not working
    It appears my auto wipers/rain sensor is not working, as when I had the wipers on the 1st setting (pressing stalk up one place) they did not get faster with heavier rain, so once it dried up a bit, I opend the drivers window and sprayed water over the sensor and window stayed open (used to close)
    The only thing I can think has caused it was when I was trying out the DRL function the other day.
    any idea how to get it working again as its a pita not having it.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Get faultcodes cleared.. if you used OP-com in the REC, and programmed anything there.. it thown on a faultcode, that you cant see with op-com, you will need tech2 to remove it, and will then again be working.
    Oct 2010
    Walkden, Manchester
    Quote Originally Posted by kenp View Post
    That will be what it is then as I changed the DRL setting in UEC & REC, cheers kenp, now to find someone near by with Tech2.
    Thanks Again.
    Engine : 2.2 Direct
    Just follow up..
    this is one of the reasons not to use op-com on the car.. as it has a fault in coding the REC, as its default setting for the rainsensor is either.. Off or Rain/lightsensor.
    But if you dont have lightsensor it will put up a error, but op-com cant see its ownfault..
    I dont know if it would be anybetter with a facelift, i actually also thinks it makes a fault there..
    Engine : 1.9 CDTi
    Isnt the rain sensor also the light sensor as he says he has the rain sensor?
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by lee gsi View Post
    auto lights werent available on half can cars which a 2003 dti would probably be
    Engine : 1.9 CDTi
    Ah I see (Best change my for sale ad then lol)
    Engine : 2.2 Direct
    lightsensor wasnt on until facelift (maby late prefacelift)
    Oct 2010
    Walkden, Manchester
    Just rang midpoint garage in middlewich and its going to be £55 if its a 2min fix but will cost alot more if it needs the variances changed. I think I might as well leave it as its a good 70 mile round trip.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Just follow up..
    I can 100% back this up. I too have rain sensor no communication along with alarm siren no communication!
    Alarm is working fine but the rain sensor isn't!
    I wish I had read this prior to dropping half the roof and rear quarter out of the car along with buying a replacement rain sensor that it looks like I didn't need!
  1. How do I work my Auto rain-sensing wipers?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2011, 11:23
  2. wipers only working on fast but not on slow or rain sesitive?
    By jafanan in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2010, 04:50
  3. automatic rain sensor wipers and lights
    By ADAM123 in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2008, 17:20
  4. automatic rain sensor wipers and lights
    Last Post: 30th May 2008, 17:10
  5. Rain sensor Wipers
    By TonyR999 in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 13:08
opel vectra c rain sensor
vectra c auto wipers
vectra c rain sensor not working
vectra rain sensor installation
lights and rain sensor on a zafira 2008 isnt workingopel insignia rain sensor not workingvectra c auto wipers not workingvectra c rain sensor is it neededhow to activate vauxhall insignia auto rain sensorsInsignia light rain sensorhow do you activate auto rain sensor in insigniavectra c rain sensor locationauto wipers setting vauxhall insignia change rain sensorsignum auto wipersvauxhall zafira auto wipers not workingopel corsa rain sensor opcomvauxhall insignia rain sensorinsignia sri facelift rain sensor location vectra c how to witch off rain sensorhttps:www.vectra-c.comforumshowthread.php142504-Auto-wipers-rain-sensor-not-workingvectra c rain sensor auto wipersopel vectra rain sensorvectra winscreen rain sensor problem
